FS Front Lowering Bracket Kit
Posted: Sat Nov 16, 2019 5:23 pm
by Henry K. Lee
Ready to go, $175.00 shipped to your door. Email if interested. Only two left!
All the Best,
Re: FS Front Lowering Bracket Kit
Posted: Sat Nov 16, 2019 5:33 pm
by Model T Tom
Looks a little thin for a suicide front end set up . but will work for stock T set up .
Posted: Sat Nov 16, 2019 5:35 pm
by Henry K. Lee
Well, it is made from 4400 series steel so thinner is a ok!
Posted: Fri Jul 26, 2024 8:19 am
by Jonathan.2909
Hi, I know that it’s an old thread but I have a question as I am building my first T and Speedster. It looks to be a piece of billet aluminum or steel in the lower mounting bracket right under where the crank goes, what’s that for and do you have any available still?
Posted: Fri Jul 26, 2024 8:53 am
Henry no longer participates on this forum. I believe the hunk of steel/aluminum is only there as a temporary filler piece used to hold everything in place for the photo.
He might still get an email if you send it through the forum "contact" icon.
Posted: Fri Jul 26, 2024 10:33 am
by Craig Leach
Hi Johnathan,
That piece fits inside the front cross member
To support it so it will not collapse because there is no spring in the U part of the cross member with the lowering bracket installed. I you go to north west vintage speedsters web site there is a section on lowering speedsters you will find detailed drawing of some of these lowering mounts along with many other ideas.
Craig.
Posted: Fri Jul 26, 2024 11:25 am
Henry K. Lee wrote: ↑Sat Nov 16, 2019 5:23 pm
All the Best,
all gone
