What have you done on an old non-Model T vehicle.
Dan Haynes
Last Name: Haynes
Re: What have you done on an old non-Model T vehicle.
Post by Dan Haynes » Mon Nov 08, 2021 9:10 pm
I always thought the Flanders was a great looking car, along with its bigger sister the Garford. Handsome, distinctive radiator shape; much more interesting than the EMF shape Studebaker later adopted as their own.
PDGx
First Name: Paul
Last Name: Grohsmeyer
* REQUIRED* Type and Year of Model Ts owned: ‘17 TT Holmes Wrecker
Post by PDGx » Mon May 23, 2022 9:05 pm
Nice Flanders.
Last Name: Strange
Post by CudaMan » Mon May 23, 2022 9:47 pm
Beatiful! :)
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Tue May 24, 2022 4:47 am
WOW ! just WOW !
Leo van Stirum, Netherlands
Post by Rich Eagle » Tue Jul 26, 2022 4:06 pm
Well, we do what we can with what we have got. I posted this 3 years ago and was quite pleased with making gears for my Buick water pump.
viewtopic.php?f=16&t=2454#p39157
The gears pumped water so much better than when they were restricting the flow rather than making it. Today a fellow posted some original ones on the Brass Buick site. Lower right in this photo. Lower left is another failed pair. I can see what they really looked like originally now.
I am happy I did what I did. If I was sure it would be an improvement I would make new ones. But perhaps what I made was a better design. :lol:
Knowing the difference is certainly a good thing.
Keep at it.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Tue Jul 26, 2022 10:47 pm
NOT a vehicle but it gets towed by 1.
1 of my neighbors I have always been able to depend on to help me if I really needed it called me 1 day last week and ask if I could help him fix his old mortar mixer. "sure". Turns out he was in the middle of a major job and needed it bad.
WOW, 1 day i will learn!
anyhow, the bearing was up in a pipe and there was no simple pulling to be done. THis is what I wound up with.
I welded 2 peices of threaded rod into the bearing and then had to cut it off the shaft and out of the pipe.Didn't scar either 1! I was LUCKY.
Last Name: Gregush
Post by Mark Gregush » Wed Jul 27, 2022 9:33 am
1920 Dodge Brothers. Replaced the whole water pump and drive gear assembly to get better shaft for pulley. Adjusted the valves. Changed the oil, topped off the transmission and rear end. Put the plates on. Washed it. Adjusted the brakes. Took for several short drives. Still looks like a "barn find", but at least I can take it for short drives, none longer than I would want to walk home, from when a tire lets its air out. :D
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Wed Jul 27, 2022 5:32 pm
After a horrified look at what new tires would cost for the Stanley sedan, it was times to stock up on jumbo-sized jugs of Blechewhite and a new box of SOS pads
5 WoodenWheels
First Name: Gerrit
Last Name: Marks
Post by 5 WoodenWheels » Thu Jul 28, 2022 11:25 am
I took my 1973 Vélosolex French motorized bike out of the garage and thought about putting the fuel system together. Then I went and did something else. Need to put the headlight assembly back on as well. Lots of work and a few parts to get it to this point, won’t bore you with details. Very popular in France for many years, cheap and reliable transportation. This one was intended for the American market, imported through Detroit which was a hub of distribution. Gerrit
Post by Rich Eagle » Thu Jul 28, 2022 1:43 pm
Dan, from my standpoint the discolored whitewalls are beautiful. Thanks for taking pictures before scouring them.
Rich :D
Last Name: Strange
Post by CudaMan » Thu Aug 11, 2022 2:55 pm
Since the heat wave broke, a friend came down to visit and help with another test drive of my 1912 Flanders 20 Runabout. This time I leaned the carb out a bit and increased the base timing, the car seemed to like the changes.
The car now goes fast enough that I need to install some cushion material around the lamp lenses before they rattle themselves to pieces. That wasn't important when the car was just a museum display, but it is now! :)
https://www.youtube.com/watch?v=09wNGLkZEMk&t=4s
paul schaefer
First Name: Paul
Last Name: Schaefer
* REQUIRED* Type and Year of Model Ts owned: 1908 S roadster, 1914 Touring,1925 touring, 1926 Truck, 1926 roadster PU, 1926 Coup
Post by paul schaefer » Sun Aug 14, 2022 7:50 am
I had the opportunity to drive Rob’s model B Ford on last Wednesdays mini tour in New London about 40 miles. The most distance a model B has traveled in 100 years. Happy to report the car performed well. Would have done the 125 mile run on Saturday but due to illness the car had to leave. Was sure an honor to be in trusted with it’s care. Hopefully it will be at OCF in September.
Post by Rich Eagle » Thu Aug 18, 2022 1:11 pm
The tail lamp on the '07 Buick had lost the knurled nut on the door. On investigating I found it loose on it's mounting on the rear bracket.
This is a fairly nice reproduction but the mounting bracket was fabricated from 4 pieces soldered together. The stress from the screw that holds it on had finally cracked and broken the lower portion at each side of the slot. While heating the remaining solder from the crack the two side pieces let go. I choose to silver solder the crack in the main piece and then soft solder the sides back on. The fact that the bracket was screwed on rather than riveted and soldered made it easier to do without getting the rest of the lamp hot.
Trying to polish just the effected areas too much polish spurted out of the bottle like ketchup sometimes does and I used it up polishing the whole lamp. I should polish all the brass more often.
Lamp work is rewarding. The heat and flux can make things look horrible but with some effort it can look wonderful again.
P. S. I did find an appropriate knurled nut and put it on very tight this time. :D
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Sat Oct 22, 2022 12:22 pm
Over the last six weeks or so, I have made a few opportunities (read that as neglecting Responsible Adult chores and obligations🙄) to work on my '14 Metz Model 22.
I removed the radiator, Again, in hopes of making a permanent repair to a persistent leak. As I was beginning to mount the radiator back into the car, I stopped and gave more consideration to a possible underlying cause to the persistent leak, something beyond my previous failed soldering jobs.
Those of you familiar with brass Ts know that, unlike the later cars with their spring cushioned radiator, the only cushion is a piece of leather under each ear of the radiator.
My Metz has none. The Metz automobile is no where near as well documented as our beloved Model T. I don't know if there was supposed to be a leather cushion used or not.
I added a piece to each side and installed the radiator. The radiator inlet and the cylinder head outlet are now better aligned than they ever have been and I am hoping that this will reduce the stress on the top tank.
There is more to reassemble and then there are few bits to fabricate for the transmission, replacing those which fell off during the last outing.
Bill Harper
Keene, New Hampshire
Post by TXGOAT2 » Sat Oct 22, 2022 12:57 pm
Does the Metz radiator have a lower mount similar to a Model T? If so, a pad both under and over the mount would probably be advantageous. If possible, a spring under the bolt head or nut would be of further advantage. More distance between the radiator neck and the water outlet would also help isolate the radiator from vibration and strain, but I don't see how that could be accomplished, other than using a "live" hose and keeping the clamps away from the ends of the metal parts. I'd want as much flexibility in the upper and lower hose connections as can be had, short of modifying original parts.
Last Name: Strange
Post by CudaMan » Sat Oct 22, 2022 2:14 pm
After fixing the water pump leak on my 1912 Flanders, I took it out for a test drive and the ignition failed, I had to have the car towed home on a flatbed. After making some checks, I'm convinced (for now) that there is a problem inside the rebuilt coil box, so I dove in and opened up that can of worms. After taking lots of pictures and making lots of notes, I plan to disassemble the whole thing, test each component, then rebuild it again with longer wires and more secure solder joints. I'm also going to attach the bottom with small screws instead of long nails to make it easier to disassemble next time.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Tue Jul 22, 2025 8:41 pm
It’s been awhile since the last post. how time flys.
After the passing of my Father in-law, my family has been honored in taking care of his classic. 1963 1/2 Ford Galaxie 500. FE 390 4V 4 speed.
I went down to Virginia with our farm tow rig to pick her up. What a beauty! I will be going through all the maintenance and getting it set up in Maryland and back out on the road. First family outing will be somewhere that has ice cream.
Bryant
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Fri Jul 25, 2025 3:43 am
Thank you for digging up this thread Bryant. I’m glad the Galaxie is going to a good home. That’s a fine machine.
I will join in too, got a new Edsel and had to replace bent pushrods and unstick valves after a long hibernation.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Fri Jul 25, 2025 10:21 am
good old Edsel
we had two here on the farm. a 58 corsair and a 59 ranger. both had FE 332 cid engines
what engine is in yours?
Bryant
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Fri Jul 25, 2025 10:31 am
The ‘58 big cars had the E475, it’s a MEL 410ci 345hp
Can’t beat an Edsel! They are my favorite
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Fri Jul 25, 2025 11:01 am
My '58 Ranger has the E400, FE 361ci 303hp
ironhorse
First Name: G.R.
Last Name: Cheshire
Post by ironhorse » Thu Jul 31, 2025 4:01 pm
After almost 3 years I am finally getting back to work on my late wife's 1972 Mercury Comet. Here's where I'm at now.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Thu Jul 31, 2025 9:13 pm
Looks like your not to far off from driving it out of the garage and to a paint booth!
How many cubes are under the hood?
Got a color in mind?
Bryant
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Thu Jul 31, 2025 9:15 pm
Tadpole
Love the big cubic inches!
The valve covers are really cool looking
Bryant
ironhorse
First Name: G.R.
Last Name: Cheshire
Post by ironhorse » Fri Aug 01, 2025 11:27 am
Bryant Main color Blue The Back panel and lower body line Satin Black And Bright work will be powder coated Satin Black
Interior Powder Blue (She Choose The Colors)
302 (5.0l for the young guys)
Post by TXGOAT2 » Sat Aug 09, 2025 11:23 am
Those MELs were fine engines. If you can't get fuel to the carburetor, check the fuel pump pushrod. Vapor lock might be an issue with modern gas, too.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sun Aug 10, 2025 11:32 am
after a short drive I decided there was something off with the transmission. Popping out of 2nd gear sometimes and the speedometer cable was whipping between 0-120 mph like crazy!
found the tail shaft bushing out. Really wrecked up the driveshaft slip yoke. Time for a rebuild.
probably caught it in time. Things look a little wore out but definitely re-buildable. Between this and the Model T auxiliary transmission build I’ve been dreaming about gears….
Bryant
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Sat Sep 06, 2025 12:33 am
I am finishing getting my 1910 Stoddard Dayton out from a deep sleep. It is an original unrestored car. Lots of little thing to check out.
Today was what I thought to be a simple fix. There is no dip stick or pet cocks to check the oil. Instead they use a sight feed glass with a rod and cork floating in the sump. The cork was heavy with soaked up oil.
I had to get cork and machine a new float, then find a steel wire for the float to fasten to. Then I had to gauge the actual diameter of the cork to allow it to float up and down in the fixed tube in the crankcase.
There are no specifications for how much oil should be in the pan when properly filled, all will be trial and error and lots of errors. I had measured how much oil I drained out, some 2-1/2 gallons. The Stoddard had a very deep and large oil pan. The Stoddard was one of the very first brass era car that had a full pressure oiling system. So I started with 2 gallons of fresh oil. Then installed the oil float tube with the new cork and extended length wire for the cork. I marked a line on the glass outer tube where the wire for the cork came up to. This adjusting the wire and oil took nearly all afternoon including adding and subtracting oil. A simple job took nearly 4 hours, and there are a number of simple fixes to get to.
Ain't restoring old car fun??????
just sayin'
fronntyboy
PDGx
First Name: Paul
Post by PDGx » Mon Sep 22, 2025 8:51 pm
Removed…..
