At the end of July / first of August, I want to get two (2) T's, both brass era tourings, transported to Rochester, NY.
I'd like for the trailer to be tall enough for the cars to ride with their tops up.
One of the T's can ride with it's top down, but the other, a '14, has never had it's top lowered since it's restoration was finished in 1995. It was explained to me that lowering and raising the top usually causes paint near the top irons to get chipped; since this is a show car, I'd like to avoid that.
They don't have to be transported at the same time; I'm assuming that to do so is less expensive than two dedicated trips.
I look forward to hearing from you.
Thanks.
Bill Everett
Want To Transport Two (2) T's to Rochester, NY, from Memphis, TN
RustyTinMan
- First Name: David
- Last Name: Phelps
- * REQUIRED* Type and Year of Model Ts owned: NA
- Board Member Since: 2022
Re: Want To Transport Two (2) T's to Rochester, NY, from Memphis, TN
Bill I responded to your e-mail did you receive this . If you still need transport give me a call 724-815-6266. Call or text me your
number . Thanks Dave's Nationwide Classic Relocation. Thanks
