Is this safe to run?
Larry e rutt
Last Name: Rutt
* REQUIRED* Type and Year of Model Ts owned: 1926 fordor
Post by Larry e rutt » Fri Jun 26, 2020 9:33 pm
I put a new fan blade on and the flange crumbled in my hand.. what remained seamed strong. My question is do u think this will last a while yet ?
Larry e rutt
Last Name: Rutt
Re: Is this safe to run?
Post by Larry e rutt » Fri Jun 26, 2020 9:34 pm
Whoops I need to add the pic[image][/image]
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Fri Jun 26, 2020 9:36 pm
Wow try this again
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Fri Jun 26, 2020 9:37 pm
Without seeing it,I would say it is not.Remember that fan is going to try to drill a BIG hole in your radiator if it gets loose.
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Fri Jun 26, 2020 9:42 pm
[image][/image]Ok I'm struggling here
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Fri Jun 26, 2020 9:44 pm
Sorry my phone is not cooperating
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Jun 26, 2020 10:11 pm
No, run without a fan until you can find a replacement, they are plentiful and cheap. Unless you are in a parade or stuck in a traffic jam, you do not really need a fan.
Post by Scott_Conger » Fri Jun 26, 2020 10:27 pm
https://www.modeltford.com/item/3004E.aspx
15% the price of a new radiator, or equivalent to 4 1/2 fill-ups in PA.
piece of mind: priceless
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Sat Jun 27, 2020 7:21 am
Ok.. thanks
Last Name: Humble
Post by Humblej » Sat Jun 27, 2020 7:55 am
Larry, while you are in there you should re-route your timer wiring harness up to the water outlet and back. Use an adell clamp at the water outlet bolt to hold it just like Henry did.
Post by Mark Gregush » Sun Jun 28, 2020 10:45 am
Wondering too about the routing of the timer wire harness? The 26/27 with coil box on the motor would have had a short harness that ran from the box over the engine down the passenger side to the timer. Cars and trucks with firewall mounted coil boxes, the timer harness would have been all on the passenger side along the frame rail. With it running along the front like that and loose, potential to cut with fan belt or? If it is the correct 26/27 harness, move it so it goes over the top of the water outlet. There would have been a wire clip that held it using the passenger side water outlet bolt.
Post by John kuehn » Sun Jun 28, 2020 10:52 am
Running without a fan is only as good as your radiator.
Post by RajoRacer » Sun Jun 28, 2020 10:55 am
Are you referring to the aluminum fan hub flange that crumbled ?
Post by Mark Gregush » Sun Jun 28, 2020 11:11 am
Adjuster, but the pulley does look a little wonky, could be the angle.
Post by RajoRacer » Sun Jun 28, 2020 11:41 am
Thanks Mark - and, I had my glasses on !
Larry - I have some of those eccentrics around here if you want to replace it.
Post by RajoRacer » Sun Jun 28, 2020 8:02 pm
Larry - I sent you an email w/photo - check your junk mail foder.
"Folder" !!!
2nighthawks
First Name: Harold
Last Name: Schwendeman
Post by 2nighthawks » Sun Jun 28, 2020 9:18 pm
....it's O.K. Steve,....sometimes dar's foder in dem' folders! :D
Larry e rutt
Last Name: Rutt
Post by Larry e rutt » Mon Jun 29, 2020 7:41 am
Sorry my email changed... try... larryrutt7at gmail.com
