Pinion Bearing question
Topic author - Posts: 178
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
I have the drive shaft ready for assembly. Before I do final assembly a question, the bearings sleeve is 3 1/16 but my bearing is only 2 7/8. 3/16 of play on the sleeve is correct. Don’t want to start tightening things up and set end play in not.
- First Name: Neil
Re: Pinion Bearing question
I should have wrote, is the 3/16 of play For the roller bearing to move back and forth between pinion gear and thrust bearings correct?
- First Name: Joe
- Last Name: Bell
The Hyatt bearing should be able to float, drive shaft should stay still on end play in the tube.
- First Name: Neil
Thank you.
