Carburetor to manifold gasket material
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by mortier » Sat Feb 13, 2021 12:22 pm
Is there a preferred material to use for the carburetor-to-manifold gasket? I have 1/16" gray gasket material.
Phil
Re: Carburetor to manifold gasket material
Post by Rich Eagle » Sat Feb 13, 2021 12:49 pm
I have used a variety of gasket materials there over the years and all have worked well.
Post by Mark Gregush » Sat Feb 13, 2021 1:49 pm
You can sure try. If it is the material I am thinking of, may be a little too hard, but then again the originals were copper covered. Nothing to loose but a few minuets work. I have used cereal boxes to make them.
Last Name: Strange
Post by CudaMan » Sat Feb 13, 2021 1:51 pm
In a pinch, I have been known to use cardboard cut out of a cereal box. :)
Post by TRDxB2 » Sat Feb 13, 2021 2:09 pm
I would use it - watch this video to see how to make it with a ball peen hammer - gently. No cutting needed https://www.youtube.com/watch?v=9Lsn6B6RsNQ
Post by Steve Jelf » Sat Feb 13, 2021 2:14 pm
I use thick gasket paper from the local parts store, but any thick paper is OK.
Dropacent
Last Name: Morsher
Post by Dropacent » Sat Feb 13, 2021 2:21 pm
I’ve always wondered why these were used originally. FoMoCo was the pinnacle of K.I.S.S. There must have been a good reason back then, otherwise they would have punched out paper gaskets. I’ve given these out as gifts for years, but just enough for me remain here.
Post by RajoRacer » Sat Feb 13, 2021 2:31 pm
I also used the sandwiched copper gaskets only because I have a large stash ! Also have them for the water connections.
Post by Norman Kling » Sat Feb 13, 2021 3:25 pm
There is no pressure on that gasket, and if the surfaces of the manifold and carburetor are clean and straight, thick paper or other gasket material would work fine. Only thing to beware of in this location would be a vacuum leak.
Post by Original Smith » Sun Feb 14, 2021 12:26 pm
Use the type of gasket Tim posted. They can be used over and over. I like the copper covered type.
Post by Steve Jelf » Sun Feb 14, 2021 12:52 pm
I use the homemade thick paper ones over and over. :D
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Feb 14, 2021 12:52 pm
If you look close, the metal edge is rolled, to make a nice seal. Remember , gasoline constantly flows through this joint. Do you really think just any material( cardboard) is a good seal? IMHO real gasket material would be a fine substitute, but not just a piece of unknown cardboard.
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Feb 14, 2021 12:56 pm
Just a small point. I believe they are actually brass, which with ford is a cheaper material. I can measure the brass thickness if anyone actually cares. It’s very thin. The core is asbestos.
Post by Steve Jelf » Sun Feb 14, 2021 1:39 pm
...real gasket material would be a fine substitute, but not just a piece of unknown cardboard.
That may be quite correct. My thick paper gaskets don't leak, but I haven't tried any non-gasket materials.
paddy1998
Last Name: Delaney
* REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
Post by paddy1998 » Sat Mar 20, 2021 11:01 pm
Should RTV be used with a paper gasket?
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Sun Mar 21, 2021 1:24 am
On the thick paper carb gasket I grease both sides so it doesn’t stick when carb needs to be removed and then reuse.
Post by Steve Jelf » Sun Mar 21, 2021 1:25 am
No. Not needed.
Post by Mark Gregush » Sun Mar 21, 2021 11:51 am
Me, reusing old gaskets. The paper gaskets are going to swell up anyway as soon as gas gets to them.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Mar 21, 2021 11:54 am
Don’t over think this. Even cardboard from a cereal box works fine as long as the manifold and carburetor mating surfaces are clean and flat.
