Sure fire way to find oil leaks
GrandpaFord
First Name: Neil
Last Name: Kaminar
Post by GrandpaFord » Tue Mar 12, 2019 1:31 pm
I rebuilt my Ruckstell and was careful to use sealant, but still have a small oil leak. It is really hard to find oil leaks because they are hard to see. I found mine by puffing colored chalk dust, the kind use for chalk lines, over suspected areas of the differential. The leaking oil washes away the chalk dust so that it is easy to see. I washed the whole differential with solvent and dried it before applying the dust. I used a new plastic bottle of the chalk dust and just puffed onto the differential by squeezing the bottle while upright. Shaking the bottle before puffing the dust helps. I suspect you can use any kind of dust, like flour, but the brightly colored chalk dust used for chalk lines is really easy to see. A very small leak, like coming through a bolt thread, just wets the chalk dust and doesn't wash it away, so it can still be seen. I hope this helps.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Re: Sure fire way to find oil leaks
Post by SurfCityGene » Tue Mar 12, 2019 1:45 pm
Grandpa, Hey Thanks that's sure a great way to find those pesky leaks. Thanks for posting a great idea!
1912 Torpedo Roadster
Scottio
Post by Scottio » Tue Mar 12, 2019 2:10 pm
My friend uses powder deodorant spray. Must be the powder spray. Works great.
Alan
First Name: Alan
Last Name: Pfau
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo, 1915 Touring, 1926 Coupe
Post by Alan » Tue Mar 12, 2019 3:27 pm
Hey Grandpa, Great tip, that's one I haven't used. Thanks for posting it.
-Al
Hal
First Name: Hal
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: '22 TT Stake Bed, '18 Touring (Hers)
Post by Hal » Wed Mar 13, 2019 7:36 am
Oh, for mine to be so small.........
Eck
First Name: William
Last Name: Sheppard
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster pickup
Post by Eck » Wed Mar 13, 2019 9:20 am
In the shipyard we mixed chalk with water to make a paste and brushed in on inspection area. Time or a little compressed air dried the paste and a leak would show up big time thru the chalk.
baltrusch
First Name: Kurt
Last Name: Baltrusch
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1918 Touring, 1922 Sedan
Post by baltrusch » Wed Mar 13, 2019 9:50 am
The powder sounds like a great way to find leaks. Another method is that auto supply houses sell a dye that you add to the oil and then use a black light to find the leak.
