Anderson style timer question
classicnvintage1
First Name: len
Last Name: doyle
* REQUIRED* Type and Year of Model Ts owned: 1927 tourer 1925 roadster
Post by classicnvintage1 » Wed Aug 18, 2021 8:45 am
Thanks to those who responded at the w/e when I was trying to identify the source of a misfire. I've now found the cause. The flapper on my Anderson style timer wasn't flapping! So, just out of contact on two cylinders. It's free now - if I slacken off the retaining nut a smidge, I guess it had tightened up of it's own accord. If I tighten to what I might call "hand-tight" the compression stops the flapper moving. Any advice welcome.
Len
Re: Anderson style timer question
Post by speedytinc » Wed Aug 18, 2021 8:55 am
The originals had a special formed retaining washer to clear the hinge. The stock, Ford washer dont quite work.
A little filing to get the hinge clearance may be needed.
Post by Mark Gregush » Wed Aug 18, 2021 9:47 am
If you click on the photo and look close, you can see the cutout on the backside. The bump on the front edge was to go over the rivet/pin head and hold the cap in place. You can get by without the bump out, but need the cutout to allow the flapper to function. https://www.modeltford.com/item/3221ANCO.aspx
Post by DanTreace » Wed Aug 18, 2021 1:10 pm
What Mark described.
The Anderson flapper must use the Anderson washer, it has a cut-away to allow the flapper to move its full travel. And has a bump out for the retaining rivet. When installing, be sure to check the placement of that washer, if any interference in operation, find the cause and fix it. The nut should be able to be fully secured like any cam nuts.
Things to check may be the flapper is hitting the front cover or oil seal or cam end (shims are provided) , perhaps too the retaining washer needs some trimming or anything you can find in a good inspection. The flapper should be free to float up and down, crank over by hand and check around the perimeter too if needed, to be sure of rotational freedom of movement.
IMG_7115 (500x375).jpg (89.06 KiB) Viewed 4523 times
Last Name: Wrenn
Post by TWrenn » Thu Aug 19, 2021 4:18 pm
Reminds me of why I absolutely love my TW timer.
All I do is keep it clean (at every oil change) and a new brush occasionally. They run smooth as silk.
Post by speedytinc » Thu Aug 19, 2021 4:31 pm
Please excuse my ignorance, but what is a TW timer?
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Aug 19, 2021 4:45 pm
In some cases, google is our friend:
https://www.twracing.com/untitled
Eric
Post by speedytinc » Thu Aug 19, 2021 5:09 pm
Eric
thanks. dosent show timer contacts. Its a roller timer with a carbon brush.
Last Name: Wrenn
Post by TWrenn » Thu Aug 19, 2021 9:57 pm
John...I guess you could describe it as that. Except its a whole LOT better and smoother running than a roller timer. Certainly no timer is 100% perfect, but this one is about as close as it gets. Even the revered New Day doesn't stack up since its brush seems to "slant" in its rotor causing it to run rough. Don't ask me how I know as they say!
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Fri Aug 20, 2021 1:07 am
Funny that, I had problems with my Anderson type timer similar to those you describe - only running on 2 at any speed higher than idle. It turns out the flapper had bent a little more than it should. I found a 'good' roller timer in my spares and installed it - the car runs nicely - better than before.
That said, the Anderson in my TT runs 'sweet as' with no problems.
Maybe it is repo manufacturing variances?
Post by speedytinc » Fri Aug 20, 2021 8:23 am
It would be nice to see the timer body inside to view the contacts& how it might differ from a stock or original unit. The ad link only shows the outside.
I currently run a new day. I custom cut a carbon brush to replace that nasty, loose brass brush. The new brush dosent seem to have the shifting problems & is easy to replace. Dosnt tear up the timer contacts. Always open to a better way/product. Thanks.
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Fri Aug 20, 2021 9:24 am
My understanding is the TW is no longer being produced.
Farmer J
Last Name: Kramer
* REQUIRED* Type and Year of Model Ts owned: 3
Post by Farmer J » Fri Aug 20, 2021 9:40 am
I agree with Tim that the TW timer is an excellent timer. However you need to watch that overtime the softer plastic between the contacts can wear down and that will leave a sharp edge on the metal contacts. When you clean your time or if you can feel that sharp edge you need to have the inside of the timer remachined so it is smooth. If you don’t do this, that sharp edge will shave off your brush in no time
Last Name: Wrenn
Post by TWrenn » Fri Aug 20, 2021 1:28 pm
Andy & Farmer you're both correct. Hopefully Tony will re-start production or someone else will pick it up. So far re the plastic insert wear, I haven't had to do much more than a very light sanding in that edge in over several thousand miles. So far, so good. Fingers crossed of course. If this timer stays out of production hopefully the New Day people will get that "brush angle issue" resolved.
Farmer J
Last Name: Kramer
Post by Farmer J » Fri Aug 20, 2021 8:45 pm
Tim, I believe that Tony still has brushes available for his timer. And I have a fixture that I can easily renew the contact surface.
Last Name: Wrenn
Post by TWrenn » Sat Aug 21, 2021 9:30 am
Jerry, yep you're right about the brushes. Thankfully they're still in production. I have two more on the way "just because"!!
