piston clearance
Topic author - Posts: 14
- First Name: MELVIN
- Last Name: king
- * REQUIRED* Type and Year of Model Ts owned: 1915@1923 roadsters
piston clearance
I just bought a set of pistons and it says 2 to 3 tho clearance, it seems tight to me ,what do you think for new pistons? MEL
Re: piston clearance
Mine .004 to .005, but I usually go with the .005. That puts it in the .001 per inch of diameter.
- First Name: Sean
- Last Name: Butler
What Mark says if the pistons are aluminum. If steel they can be a bit tighter.
- Last Name: Gulbankian
It depends on condition of the block: We thermal clean the engines so they get the heat transfer. We set our cylinders to their recommended 3 thousandths clearance and have never had and issue.
