Support Forum
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Post
by MichaelPawelek » Thu Dec 30, 2021 7:31 pm
As you all know I am a electrical dummy so please don’t laugh at this question as someone recently posted about wires too close together causing electrical interference.
The number 4 spark plug wire in the picture from the coil box post to spark plug runs right next to the lower coil box post which I believe is from the ignition switch to the coil box. As long as they do not touch and are insulated is this a problem?
- Last Name: Strange
Post
by CudaMan » Thu Dec 30, 2021 8:06 pm
Probably OK, but if it was that way on my car I would fix it. If you are using pre-cut spark plug wires from the vendors, put the shortest wire on plug #3. This will give the wire for #4 just enough extra length to give you some extra clearance.
Post
by John kuehn » Thu Dec 30, 2021 8:09 pm
I bend the plug terminal up and move the plug wire away from the coil box terminal. Retighten the plug wire in the newer position and it’s good to go. It’s not touching anything in that position.
Your probably OK as yours is but I try not to let any plug wires touch another terminal even though they are insulated. Ford probably didn’t do it when the cars were new.
- Last Name: Humble
Post
by Humblej » Thu Dec 30, 2021 8:18 pm
I think Mark is on the right track, #4 wire is too short. I checked my original wires on my unrestored '24, and #3 and #4 wires are the same length. If your new wires have four different lengths, swap #3 with #4, #4 should not be the shortest wire.
Humblej on Thu Dec 30, 2021 10:37 pm, edited 4 times in total.
Post
by TXGOAT2 » Thu Dec 30, 2021 8:19 pm
It's best to keep the high tension plug cables 1" or more away from each other or anything else. Also check that linkages do not move into contact with the plug cables when the controls are operated. It's common for plug wires to leak current to anything near them. Inductive coupling can also occur, but is less likely than insulation leakage. All high tension insulators, including the plug insulators and coil box and coil casing parts exposed to the high tension current, need to be kept clean and dry. Any wood exposed to high tension current that is dirty or in such a condition that it can absorb moisture is likely to leak current. Any slight leakage will usually cause carbon tracking, which leads to more leakage.
Post
by Steve Jelf » Fri Dec 31, 2021 10:51 am
The short answer is yes, it can be a problem. I suspect it's the reason my magneto needs a recharge. Keeping the plug wires at least ½" apart from each other and from other wires may be good enough, but I'll go for an inch.
Post
by Original Smith » Fri Dec 31, 2021 11:11 am
That's the reason they have insulation on the wires! When I did mine, I referred to the Ford Service book, and routed my wires exactly the same as the pictures in the service book.
Post
by TXGOAT2 » Fri Dec 31, 2021 11:29 am
On the 1928-'31 cars, Ford did away with all insulation on the high tension side and used bare metal conductors to carry the high tension current from the distibutor to the spark plugs.
MichaelPawelek
Post
by MichaelPawelek » Fri Dec 31, 2021 11:49 am
Yes, I have seen barbed wire used as a joke!
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Post
by ThreePedalTapDancer » Fri Dec 31, 2021 12:03 pm
- C81BD732-3791-4E01-8DC1-CB6FEEEA85A8.jpeg (122.39 KiB) Viewed 2692 times
Post
by Allan » Fri Dec 31, 2021 7:07 pm
Might the loom wire to the coilbox be routed around the end of the terminals rather than down through them. It works on or RHD cars.
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Post
by mtntee20 » Fri Dec 31, 2021 7:24 pm
I'm a little surprised that some "Old Timer" hasn't suggested this test already. So, this "Old Timer" is going to make the suggestion.
Take your car to a DARK area. Start it, open the hood, and look for sparks from the high tension (spark plug) wires. You'll be able to see sparks between the plug wires and anything else. Then, you'll know exactly where the problems are.
Good Luck
- Last Name: Humble
Post
by Humblej » Sat Jan 01, 2022 11:21 am
Allen, This is how the USA left hand steering firewall configuration is in the Ford Service Manual copyright 1926.
Post
by Allan » Sat Jan 01, 2022 10:32 pm
Thanks Geoff,
There does seem to be plenty of length in that wire to route it down past the end of the box and along under the spark plug terminals to keep it out of the way.
Don Lyon
- First Name: Don
- Last Name: Lyon
- * REQUIRED* Type and Year of Model Ts owned: '24 Roadster
Post
by Don Lyon » Sun Jan 02, 2022 11:13 am
Run your motor in the dark, sparks jumping between wires will easily become evident. My Dodge was running poorly until I opened the hood one night out in the driveway and saw the lightshow. Had sparks jumping from the spark wires to the headers on 4 cylinders. Don.
been there, broke that
