Seat upholstery kit
Mark Osterman
Last Name: Osterman
Seat upholstery kit
Post by Mark Osterman » Fri Apr 12, 2019 6:03 am
I’m starting to think about replacing my seat covers on the ‘23 runabout. I love the fact that my car has original upholstery but I drive it so much that it’s not going to survive much longer. So, I’m buying a new seat bottom spring and am thinking of buying the seat cushion kit from Langs. Anyone out there used their kit and have opinions. I made all my leather upholstery from scratch for my last T but have never used a vinyl ready made kit before.
RustyFords
First Name: Don
Last Name: Allen
Re: Seat upholstery kit
Post by RustyFords » Fri Apr 12, 2019 7:49 am
I'm thinking about doing the same thing Mark, so I'm interested in the feedback you get.
1924 Touring
john in kzoo
Last Name: Seelman
* REQUIRED* Type and Year of Model Ts owned: 15 touring
Post by john in kzoo » Fri Apr 12, 2019 8:10 am
I used the kit from Clastique. Couldn't be happier
SVibert
First Name: Spencer
Last Name: Vibert
* REQUIRED* Type and Year of Model Ts owned: 1927 touring
Post by SVibert » Fri Apr 12, 2019 8:34 am
Get the Classique kit you will like it
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Fri Apr 12, 2019 8:45 am
I used Clastique for my '14 runabout and was very satisfied.
Last Name: Wrenn
Post by TWrenn » Fri Apr 12, 2019 9:09 am
Mark...by all means...only use Classtique! And by all means, also, I would HIGHLY suggest
you pony up a little extra and just have Mike do the seat bottom work there. Trust me, it's worth
every extra penny! Just ship him your springs and wait for the excellence to return. I also had Elizabeth
from "Class it Up" come out and do the seat backs. Again, money well spent! Just my two cents!
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Fri Apr 12, 2019 10:14 am
So, I was actually asking about the kit that Lang’s has in their catalog. Is this one made by Classique or do you have to order from them?
Is the Classique that much better for over a $100 difference?
I have reupholstered from scratch. Here is the vintage seat assembly from my old speedster that I rebuilt using leather from a sofa I found on the curb. Also built the bottom assembly from scratch. So, maybe I can do the seat bottom myself. I see that these are compressed during the covering operation.
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Post by Jim_PTC_GA » Fri Apr 12, 2019 10:42 am
I used the Clastique kit with no problems. 24 Roadster.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Gary Gregory
First Name: Gary
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster
Post by Gary Gregory » Fri Apr 12, 2019 11:46 am
I can tell you I've dealt with Don Lang personally and he will treat you right. I'll probably be ordering the upholstery for my 27 Roadster from him. How much difference are there from the kit from Langs and a kit from Classtique ?
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Fri Apr 12, 2019 12:58 pm
I've heard people have good luck with Cartouche (which I think is the kits Langs sells), but I have not personally had any experience with it. I used Classtique just like most have responded.
I also know people who have used Cartouche and said they never would again: Ill fitting and made wrong.
William L Vanderburg
1922 Center Door Sedan
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Fri Apr 12, 2019 3:11 pm
Ok .. so that is scary to hear. I have heard a lot of good things about Classique ... so the extra $100 + is worth it?
Gary Gregory
First Name: Gary
Last Name: Gregory
Post by Gary Gregory » Fri Apr 12, 2019 3:38 pm
I'd would like to hear from guys who have used Cartouche if this is what the vendors are selling.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Fri Apr 12, 2019 4:39 pm
I have used Cartouche upholstery and top kits about 6 or 8 times Every thing I got from them needed replacement of at least one part of these kits. Made wrong or wrong size. Ok after having them correct the problems. Only used them because my customers wanted the cheapest. Sure miss Carters cut and cover.
SVibert
First Name: Spencer
Last Name: Vibert
Post by SVibert » Fri Apr 12, 2019 10:52 pm
The answer to your question Mark is this for a $100 extra I would go with the Classique kit I had a cartouche kit in my 26 roadster and hated how it was built
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Sat Apr 13, 2019 8:35 am
One caveat. Regardless of who you order your cushion kit from, you need to specify if you want the factory crimping rope sewn into the bottom cushion hem. I received one kit where it was assumed I would hog ring the vinyl under the cushion.
Tom Miller
Post by Steve Jelf » Sat Apr 13, 2019 9:47 am
The question of Cartouche is moot. If any of the dealers have their stuff in stock, when it's gone there won't be any more. The company has gone belly up.
Gary Gregory
First Name: Gary
Last Name: Gregory
Post by Gary Gregory » Sat Apr 13, 2019 6:16 pm
Steve I think you're a bit confused. It was Labonny that closed its doors. Unless Cartouche did also ????
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Sat Apr 13, 2019 6:20 pm
Cartouche would impossible to find information on. I've done deep dive searches for it, and it only comes up with Mac's as an authorized dealer, although I know other dealers sell them.
Post by Mark Gregush » Sun Apr 14, 2019 10:48 am
Re;"Cartouche would impossible to find information on" Did a quick check, lots of dealers carry it' but couldn't find any info on who makes it. Cartouche is a trademark not a company from what I could find.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Sun Apr 14, 2019 12:06 pm
If it's a trademark, then who the hell is the manufacturer?
Post by Mark Gregush » Sun Apr 14, 2019 12:38 pm
Good question. Maybe call Lang's or one of the other suppliers.
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Mon Apr 15, 2019 7:46 pm
Cartouche is owned by Mac's. I guess that you could call it a side or back room operation. And, yes, they do sell it to most of the Model T parts vendors.
Bill Harper
Keene, New Hampshire
Post by Original Smith » Tue Apr 16, 2019 11:41 am
Mac's is in fact Car Touche. I've not heard one good thing about them. I would go with Classtique. I know Langs sells their kits but I still wouldn't do it.
Last Name: Hjortnaes
Post by DHort » Tue Apr 16, 2019 8:59 pm
Cartouche made my top. It took me three years to install it. The original was too small. I mailed it back to them and sent me a new top with my measurements. It fit just fine. Cartouche took care of me, and I am happy with their service.
