1913 Holley S Carb Valve Seat Differences. Anyone know why?
Benji
First Name: Benjamin
Last Name: Eckstein
* REQUIRED* Type and Year of Model Ts owned: 24 Roadster Pickup, 13 Runabout, 13 Touring, 14 Light Delivery, 15 Speedster
Board Member Since: 2012
Post by Benji » Mon Jul 18, 2022 11:10 pm
So I found another Holley S carb in the house, so I have 3 now to look at.
I cracked open all 3 to see whats going on inside.
2 have the same valve seat, and the third one has a completely different one.
As you can see, it has a guide for the valve needle, whereas the others do not.
Is this a later addon, or is this an earlier version?
Benji
Last Name: Eckstein
Re: 1913 Holley S Carb Valve Seat Differences. Anyone know why?
Post by Benji » Tue Jul 19, 2022 3:04 pm
Anyone know about early carbs?
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Post by richc » Tue Jul 19, 2022 5:28 pm
I have three 1913 Holley S carburetors, as well. All have the valve needle guide.
Rich C.
Benji
Last Name: Eckstein
Post by Benji » Wed Jul 20, 2022 12:16 am
Thats interesting. Some pics I found on the forum (new and old), don't show the needle guide. I wonder if it's an earlier design?
I think ill keep the needle guide carb for the 13 runabout.
Rich C.
Tony Delbianco
First Name: Tony
Last Name: Delbianco
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout
Board Member Since: 2022
Post by Tony Delbianco » Wed Jul 20, 2022 1:12 am
I have two of these carbs as spares...Both of them have the needle guide, and I think the one on my car has it too...It looks like the guide is a separate part and has four punch marks spaced around the perimeter to hold it in place...perhaps yours were removed or came loose and fell out...the punch marks are easier to see on mine if the Strangling Tube (the throat that is held in place by the big spring clip) is removed.
Tony
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Thu Jul 21, 2022 9:38 am
I think those get broken when people try to remove them? I don’t know what else would cause them to break unless the pot metal finally gave way to vibration. I’ve made several of those from a roll pin and a fender washer then it swaged right back in by expanding the 4 slots with a small screwdriver.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Thu Jul 21, 2022 9:49 am
Some of those have a restricted fuel inlet while others are straight through to the seat opening.
