Closed Cab Pickup ?
Topic author - Posts: 95
- First Name: Kevin
- Last Name: Mocyk
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Closed Cab Pickup ?
While I realize Ford never made a closed cab pickup, I wonder if I could get opinions on what year and model of closed car this one started out as. Sure looks nice!
- Attachments
- 411D7014-B1FF-4773-B710-5EF152C5CC6A.jpeg (37.55 KiB) Viewed 2675 times
- A92B55F7-1B70-4BBE-8CC3-1F285AADF677.jpeg (35.91 KiB) Viewed 2675 times
- 92F2FD06-37AE-4597-A961-C369C303E314.jpeg (34.65 KiB) Viewed 2675 times
- CF22D31E-3BD8-4D32-ACDA-AFC62E4475B7.jpeg (33.27 KiB) Viewed 2675 times
- First Name: Kevin
- Last Name: Pharis
- First Name: Mack
- Last Name: Cole
Re: Closed Cab Pickup ?
If that had a metal bed modified a bit to fit better to the back of the cab,that would be 1 of the coolest T's I have seen in a long time.
- Last Name: House
‘24-‘25 coupe. LR fender points to ‘25. Rear of cab too nicely done for a sedan.
- First Name: Kevin
- Last Name: Matthiesen
While I can’t say for sure on this one, many of the closed Model T’s converted to closed cab pickups were done using 1924-25 or 1926-27 Tudor’s. On the 1924-25 T’s the Coupe’s attached deck made this conversion harder. I would say this T pickup was once a 1925 4 door in this case, because of short front doors from a 4 door and the 1925 rear fender although the front fenders look like they are the 1924 type with the exposed bead.
There is a 1926 Lincoln in this area that was given a similar treatment. Whoever did it did a first class job.
I believe this shows that it was a 1924-25 Tudor. The door proportions, visor, cowl and splash apron look exact to me. The rear upper body panel does look different but I don't believe it is Coupe or Fordor. Maybe custom or extended. There is a vent in the cowl although not clearly seen. Coupe and Fordor doors were not that wide.
It would certainly be a fun car.
P.S. This shows the same view of a coupe. Notice the narrower window and transition to trunk.
We had a '24 Packard and some Buicks with that treatment in our area. It was a typical modification.It would certainly be a fun car.
- First Name: Bryant
- Last Name: Shafer
This one is a shortened Tudor
- First Name: Kevin
- Last Name: Mocyk
Wow! Thank you one and all, this is some really great information. Makes it clear it was a Tudor.
Has anyone ever documented this conversion that would like to share their experiences?
- Last Name: Shafer
Bear with me here as Iam not advocating for hot/rat rods but this idea has crossed my mind. Taking a Tudor or fordor and adding a bed to the back of it. Obviously it would take some fabrication to the chassis components. Linda like the family extended cab/crew cab pickup.
this picture is only for the general idea. One with actual T body parts ,chassis ,wheels would be spectacular.“Whether you think you can, or think you can’t-you’re right.”
- Last Name: Michaelree
- Board Member Since: 2010
Ha Rich, that must have been custom built for Robert Wadlow.
- Last Name: Shafer
Rich I love it! For long journeys so you can stand up or for special occasions when you wear your 10 gallon top hat
