Valve Seals advice
Re: Valve Seals advice
Post by Scott_Conger » Sun Nov 13, 2022 10:02 am
....No....
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Sun Nov 13, 2022 1:27 pm
Valve seals no. Valve seats sometimes.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Nov 13, 2022 2:04 pm
Webster may be referring to the Secrets of Speed using felt washers to stop air & oil leaks in engines run at sustained high speeds.
I would suspect seals in a normally run engine would rob the valves of any lubrication they get in a flat head engine.
