number 1 and 2 cylinder plugs carboned up
stevefa1952
First Name: STEVEN
Last Name: FALCK
* REQUIRED* Type and Year of Model Ts owned: 1917 touring
Post by stevefa1952 » Tue Feb 07, 2023 5:16 pm
Motor seems to be missing and running rough. Number 1 and 2 plugs are carboned up with a little clean spot on tip of spark plug. Numbers 3 and 4 are super clean.
Is it a timer problem or coils or something else?
no trouble starting the car. Just does not sound correct.
Steve
Re: number 1 and 2 cylinder plugs carboned up
Post by TXGOAT2 » Tue Feb 07, 2023 5:23 pm
Not an uncommon problem. Several things could cause it, with a leaking manifold gasket being one.
MKossor
Last Name: Kossor
Post by MKossor » Tue Feb 07, 2023 5:25 pm
Optimal engine performance depends on many variables. Start/resolve with the easy ones and address all until the engine performs to your satisfaction.
Clean/gap plugs, Clean/replace timer, clean/replace coil points, properly tune coils for equal and consistent firing Time, run compression or leak down test on all cylinders to check valves for good/uniform compression. Good luck with your troubleshooting and repair.
Post by Scott_Conger » Tue Feb 07, 2023 5:26 pm
leaking manifold is almost always the problem
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue Feb 07, 2023 6:57 pm
I was having trouble with #1 and #2 spark plugs getting very oily. After doing a lot of work that didn't solve the problem, i discovered that I was over filling the engine oil. I thought more is better. Reduced the oil level to just barely at the upper valve. The problem was solved.
Art Mirtes
Post by Norman Kling » Tue Feb 07, 2023 8:23 pm
If the carbon is oily, you are burning oil, however if it is black you are running rich gas mixture. Since it is on 1 and 2 I would very much suspect that the intake manifold gasket has a leak on 3 and 4. Since they have the same port of the manifold. If it sucks in air at that point, the mixture needle is enriched to compensate for extra air going into 3 and 4. The manifold connection for 1 and 2 is normal, so when the mixture is enriched, those two cylinders run rich. The cure for this problem is new manifold gaskets. The ones with glands and copper rings seal the best if the surfaces of the manifold and block are clean. The exhaust manifold must also be straight so that the ports align with the ports on the block.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Feb 07, 2023 8:29 pm
#4 cylinder runs considerably hotter than #1.
#3 runs hotter than #2. This is the reality of the engine cooling system.
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Feb 08, 2023 1:04 am
Hi Steven,
One thing at a time. Start & warm up the engine. Adjust the mixture to to as lean as it will run good, get a fire extinguisher, then spray a
flammable substance on the intake manifold making sure not to let it get close to the carb inlet. If the RPM comes up then it's a good
chance you have a intake manifold leak. If not swap #1 & 2 coils with # 3 & 4 and see if the issue fallows the coils. Try the same with
the plugs. If not look at the timer if you don't find a issue there then it's time for a compression test. Because of the 1-2-4-3 firing order
of a T many things effecting # 1 or #2 or #4 & # 3 will cause a miss in the next cylinder.
Good luck.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Wed Feb 08, 2023 7:10 am
The problem with # 1 and # 2 is already in the Book :
The Model T FordOwner by Murray Fahnesstock 1921 .
pag.303-305 .
Toon
