1926 TT Seat Frames
Topic author - Posts: 39
- First Name: Joe
- Last Name: Jennings
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
1926 TT Seat Frames
Does anyone have a good picture of how the rear seat cushion attaches to the cab. I have a factory steel body truck.
- First Name: Chris
- Last Name: Hansen
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT, 1927 Tudor
Re: 1926 TT Seat Frames
I don't have a picture, but the rear seat cushion fastens to the rear panel of the cab through 2 slots in the stiffening rail just above the rear seat. The rear seat spring has small "j" shaped protrusions above the spring frame which goes through the slots and locks the back cushion in place. Good luck. Have fun with the TT. ---Chris Hansen
- First Name: Joe
That is great information, my seat frame does have J hooks on the top and bottom of the frame.Chris Hansen wrote: ↑Tue May 21, 2019 9:21 amI don't have a picture, but the rear seat cushion fastens to the rear panel of the cab through 2 slots in the stiffening rail just above the rear seat. The rear seat spring has small "j" shaped protrusions above the spring frame which goes through the slots and locks the back cushion in place. Good luck. Have fun with the TT. ---Chris Hansen
Thank You for your help.
