shocks
Philip
First Name: Philip
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
shocks
Post by Philip » Mon Jan 22, 2024 2:53 pm
looking for information on putting modern shocks on a model t. what shocks and how to mount.philip
Philip
First Name: Philip
Last Name: Thompson
Re: shocks
Post by Philip » Mon Jan 22, 2024 3:15 pm
there was a thread on the subject but i have no luck searching anymore
Last Name: Strange
Re: shocks
Post by CudaMan » Mon Jan 22, 2024 3:31 pm
Philip
First Name: Philip
Last Name: Thompson
Re: shocks
Post by Philip » Mon Jan 22, 2024 3:43 pm
thanks mark i found that one there is one somewhere that shows the fronts
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: shocks
Post by MichaelPawelek » Mon Jan 22, 2024 6:18 pm
Phillip, In the past on a Touring and a Coupe I found the ride greatly smoothed out by refurbishing and lubricating both front and rear springs. A stiff ride is generally an indication of worn and non lubricated spring set up. The Model T rides quite comfortably when the springs are in good shape…
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: shocks
Post by Rich P. Bingham » Mon Jan 22, 2024 7:25 pm
Another aspect of "ride" is tires. Recently changed out old rock-hard tires for new, fresh, pliable tires and the difference was remarkable!
Get a horse !
Bill Mullins
First Name: Bill
Last Name: Mullins
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Re: shocks
Post by Bill Mullins » Mon Jan 22, 2024 11:12 pm
My method is using 1965 & earlier VW shocks front & rear.They work very well as Tom says the rear make the big difference.
Bill Mullins
First Name: Bill
Last Name: Mullins
Re: shocks
Post by Bill Mullins » Mon Jan 22, 2024 11:15 pm
First Name: Austin
Last Name: Farmer
Re: shocks
Post by 1925 Touring » Tue Jan 23, 2024 12:40 pm
Its not your fault, its googles fault. It wont show mtfca search results anymore.
If you switch to a different search engine you may have more luck with a search.
Philip
First Name: Philip
Last Name: Thompson
Re: shocks
Post by Philip » Tue Jan 23, 2024 2:13 pm
bill can you give me a picture of the mounts?
SurfCityGene
First Name: Gene
Last Name: Carrothers
Re: shocks
Post by SurfCityGene » Tue Jan 23, 2024 10:04 pm
Philip, The ones I have seen on the NW Montana 500 racers where smaller VW type and attached directly to the differential tube. They were Much less offensive looking than some others but not Model T era for sure. If you can find a picture of Tom's I would copy his idea and could easily be home built.
1912 Torpedo Roadster
