Pressure regulator
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Pressure regulator
Post by Ralph F » Sat Jun 08, 2024 11:42 am
Reel pump
Reel pump
I have a speedster with reel rotary oil and looking for a pressure regulator.
Les Schubert
First Name: Les
Last Name: Schubert
Re: Pressure regulator
Post by Les Schubert » Sat Jun 08, 2024 4:33 pm
Are you actually pressuring the bearings. If so then perhaps look at air pressure relief valve.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Jun 09, 2024 1:39 pm
That looks like a Oberdorfer brass gear pump they can be purchased with a adjustable relief valve built in. You maybe can buy just the head new?
The grease zerks indicate it could also be a Dayton.
