Does anyone know where I can purchase a rolling engine cradle for a 1935/36 Ford flathead engine?
Thnak you , Craig
Engine cradle
Craig E. Luton
Topic author - Posts: 191
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Craig E. Luton
- First Name: Craig
- Last Name: Luton
Re: Engine cradle
Does anyone have any info on the engine cradle I am inquiring about?
- Last Name: Humble
Re: Engine cradle
An engine stand? A rebuilding roll around stand that the engine can be rotated right side up and upside down? I used a modern engine stand from Harbor Freight for my 1939 Ford V8.
Chuck Regan
- First Name: Chuck
- Last Name: Regan
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
Re: Engine cradle
Craig - a quick internet search show a couple types of flathead cradles. If you weld they are a simple fabrication project. I made mine out of some 3/8” steel plate and scrap square tube - with ACE Hardware casters. For any pre-8BA flattie, I use the exhaust flange for my engine stand adapter and cradle attaching points to avoid potentially cracking the early cast-in bell housing.
