Exhaust could use your hot opinions
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Feb 01, 2025 9:58 pm
I think this only took a few minutes.
Could use your "hot" opinions.
Vern (Vieux Carre)
Moxie26
Last Name: Jablonski
Re: Exhaust could use your hot opinions
Post by Moxie26 » Sat Feb 01, 2025 10:11 pm
Wow 😲..... Maybe your exhaust valves need to be replaced due to excessive clearance at lifter, and maybe fuel mixture is a bit too lean ?
Daisy Mae
First Name: Kurt
Last Name: Andersson
Post by Daisy Mae » Sat Feb 01, 2025 10:14 pm
You're running WAY lean.
Check your carb, as well as look for any intake leaks at the carb to manifold, as well as manifold to block gaskets would be my first places to look.
Other culprits being timing or valve issues.
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Post by South Park Zephyr » Sat Feb 01, 2025 10:45 pm
When I first put mine together, the timing was off and caused the manifold to overheat and glow red. It also showed me that I had a coolant leak in the front cylinder.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat Feb 01, 2025 11:42 pm
Get out the manifold cooker and steaks.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sun Feb 02, 2025 5:37 am
Too lean and/or timing too retarded.
bobt
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1915 touring 1926 roadster
Post by bobt » Sun Feb 02, 2025 5:51 am
ADVANCE THE TIMING!!!
Post by TXGOAT2 » Sun Feb 02, 2025 9:32 am
Very late timing. That will destroy valves, crack blocks, and fry exhaust manifolds.
First Name: Austin
Last Name: Farmer
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by 1925 Touring » Sun Feb 02, 2025 10:00 am
I had the same issue with my car when I first started running it. My exhaust pipe would glow red after only a few minutes of running. I was running the car to lean and my timing was off. After fixing those things it did not glow anymore. In the meantime you should be able to set a world record for how fast you can cook meal on a model t!
Post by TXGOAT2 » Sun Feb 02, 2025 1:26 pm
The exhaust manifold should never glow red, even if you are climbing Pike's Peak.
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Sun Feb 02, 2025 4:11 pm
Vernon,
I have to remind my son quite regularly, start with the simple stuff first.
Fuel too lean, timing too retarded.
Hope that helps,
Kevin
PS my son would have the engine pulled out of the car on the garage floor and half way apart by the time I got out to the garage to answer his question about what as causing this condition!!!! The whole time standing there with his phone in hand saying "But Youtube said.........
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Feb 02, 2025 8:45 pm
I had a problem years ago that only one area of the manifold was getting red like that.
I found that due to a bad coil, one cylinder dumped the gas charge in the exhaust manifold, and the next cylinder to fire ignited the charge in the manifold with that discharge, also due to the timing being off.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon Feb 03, 2025 7:57 am
I have not yet replaced the floor boards from when I swapped out the pedal return springs and for that reason, i caught this very quickly on camera. I forgot to advance the timing, then lowered the throttle, realized that the choke was still pulled out and pushed it in and finally switched over to magneto. by the time I made those four corrections, the exhaust color had instantly improved. Looks like the timing rod needs further adjustment.
Vern (Vieux Carre)
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon Feb 03, 2025 9:06 am
Vernon,
The timing rod gets adjusted only to provide spark just after TDC with the spark lever fully retarded.
The engine shouldn't be able to run with the choke out, the throttle advanced, and the spark retarded.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Tue Feb 04, 2025 1:51 pm
When I bought my 1927, I had to get new floorboards, as those were all covered with a thick layer of carbon, because the exhaust pipe was cherry red and started the fire.
The temperature was only about 40 degrees on that late fall tour in Maine and the owner just thought everyone had started their wood stove early!
