Stutz Dual Cap Distributor
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Wed Feb 26, 2025 8:16 pm
I just bought a car with a Morton and Brett OHV head on it. The car is set up to use the type of distributor used on four cylinder Stutz and a couple other makes. My distributor is missing and I need a replacement. If you know of one PLEASE let me know.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Stutz Dual Cap Distributor
Post by Dan McEachern » Wed Feb 26, 2025 10:50 pm
Contact Tom Van Meeteren- he specializes in early ignition parts and probably has what you need. Just FYI, it is possible to adapt early 4 cyl Jeep cap and rotor to a Stutz ignition. The rotor fits right on the dist cam, but the cap needs some lathe work and a lock ring for the OD to retain the cap on the clips.
Here is the e-mail I have for Tom- he posts on here from time to time.
tsvanmeet@gmail.com
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Feb 27, 2025 9:54 am
That’s good to know Dan. I got rid of one because the “correct” parts were were really expensive.
Andy
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Thu Feb 27, 2025 11:56 am
Chris, you might find some useful information in this thread:
viewtopic.php?f=2&t=43141&p=348676#p348676
Dan McEachern
First Name: DAN
Post by Dan McEachern » Thu Feb 27, 2025 10:24 pm
A dusty picture is better than no picture............
Bob in ohio
First Name: Bob
Last Name: Gairing
Post by Bob in ohio » Fri Feb 28, 2025 9:51 pm
Dan- can you post the year of jeep or part number of the distributor cap and rotor that will work with the early Delco unit?
Dan McEachern
First Name: DAN
Post by Dan McEachern » Fri Feb 28, 2025 10:12 pm
I made this 35 years ago, but pretty sure they are '48 4 cyl Jeep with Autolite IAD series distributor. Cap is a Standard Motor Parts AL35.
The Rotor is a Standard Motor Parts AL85. The rotor is a drop in. The cap needs to be machined to the proper height and to register on the Delco Remy /Stutz housing.
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Sat Mar 01, 2025 2:23 pm
Thank you Dan, This info certainly spares much frustration and dollars finding caps and rotors.
Bob in ohio
First Name: Bob
Last Name: Gairing
Post by Bob in ohio » Sat Mar 01, 2025 7:43 pm
Thanks Dan, I just bought a cap and will try to do the modification.
