Plans for huckster
Bigcth61
Topic author - Posts: 15
- Last Name: Henry
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring, 1925 roadster
Plans for huckster
I’m looking to put a roof on an open huckster. Seeing if anyone had any plans on how to build it. Thank you
Tbird
- First Name: Mike
- Last Name: Bird
Re: Plans for huckster
Tim, so I haven’t built a huckster, but I am building a delivery car. The way the roof is constructed might be pretty similar. The roof section consists of 1” wide 5/16” thick slats that run from front to back and are spaced 3/4” apart. I’m using maple but what ever wood species you desire can be used. The slats are then nailed onto the roof bows. I will then cover the slats with batting over the top then followed by duck canvas (pre washed) stretched over the batting. Have fun!
Nate22huckster
- First Name: Nathan
- Last Name: Fahrni
- * REQUIRED* Type and Year of Model Ts owned: 1922 huckster, 1925 tudor, 1926 TT dump truck, 1927 tudor
I don’t have plans but if you need any dimensions off of mine let me know
Bigcth61
- Last Name: Henry
Thank you!
