Pressurizing Gas Tank
Rod
Topic author - Posts: 97
- First Name: Rod
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
- Board Member Since: 2014
I finally took George Akins advice and pressured my fuel tank using the exhaust on my 1924 Depot Hack. For years I have had trouble climbing hills unless my tank was completely topped off.
To the neigh sayers, there is no risk of explosion. Any oxygen in the tank is displaced by carbon monoxide. There is an aticle in the MTFCA Carburetor book which explains how to do this work, taken from Model Airplanes which use the exhaust gas to pressurize the fuel.
I bought these things from Amazon
SENCTRL 0-3 Psi Low Pressure... https://www.amazon.com/dp/B0C624GLKD?re ... b_ap_share
HEROFFIX 1 Pcs AN6 Fuel Line Hose... https://www.amazon.com/dp/B0DN1XWBRJ?re ... b_ap_share
Shineyoo 6AN Straight End Fitting... https://www.amazon.com/dp/B095H8WFMJ?re ... b_ap_share
By adding a one way valve, I now have steady pressure in the tank. I also added the stainless fuel filter to act as a spark arrestor.
Look me up at Homecoming in June and I can show you the setup. Here are some pictures.
- First Name: Henry
- Last Name: Lee
Re: Pressurizing Gas Tank
Yes Rod...., it does work well!
schwabd1
- Last Name: Schwab
So, your out running your T on a 95 degree day. You notice your fuel is running low, let’s say 1/4 tank. By the time you get home the gas is at 1/8 of a tank with the other 7/8 full of warm air. It gets rather cool over night, the air in the tank cools down. With the one way valve wouldn’t that create a negative pressure in the tank? I’ve heard stories of tanks denting in that situation. I want to add a hand pump to the speedster I’m building, but can’t get a plumbing system in my head to relieve both excess and negative pressure.
Rod
- First Name: Rod
Negative pressure doesn’t exist. The one way valve is designed for low vacuum or pressure. Anytime the pressure in the tank goes negative, the valve opens thereby eliminating the condition you are describing of the tank collapsing.
The valve was added because the pressure gauge was bouncing quite a bit with each pulse of the exhaust. Now the pressure stays steady. The tank even holds pressure after the engine is turned off.
babychadwick
- First Name: Chad
- Last Name: Azevedo
A simple check valve that is held shut when the pump pressurizes will allow air to fill the void. On this example the check valve does exactly that when the engine is off as the exhaust it open to the atmosphere.schwabd1 wrote: ↑Fri May 16, 2025 4:51 pmSo, your out running your T on a 95 degree day. You notice your fuel is running low, let’s say 1/4 tank. By the time you get home the gas is at 1/8 of a tank with the other 7/8 full of warm air. It gets rather cool over night, the air in the tank cools down. With the one way valve wouldn’t that create a negative pressure in the tank? I’ve heard stories of tanks denting in that situation. I want to add a hand pump to the speedster I’m building, but can’t get a plumbing system in my head to relieve both excess and negative pressure.
My only concern would be to insure there is a shutoff on the carb to prevent a hot tank pumping thru a leaky float valve.
Rod, do you have the same problem with your other T's?
Rod
- First Name: Rod
My 1910 and 1913 don’t seem to have the same problem as those gas tanks are mounted higher and closer to the carb than the Depot Hack.
My Depot Hack does have a carb shut off valve.
Round tanks and oval tanks are mounted at near identical heights above the frame rails. the oval tanks may look to be lower, but it is only the shape that gives this impression. The last gallon in the tank is at the same height. Being further back, the depot hack may suffer starvation earlier in hilly country, but otherwise the delivery should be the same, if everything else is in order. Adding pressure to the tank simply forces fuel past what may be an unintended restriction. No doubt it may work, but it is treating the symptoms rather than the cause. Or, I maybe barking up the wrong tree, again.
- Last Name: Humble
I am refraining from responding to this post because I do not want my fingerprints on this if it results in a lawsuit.
NoelChico
- First Name: Noel
- Last Name: Chicoine
I've seen this idea elsewhere and am glad you put it on your hack. No more need to be towed out of deep, off the tour route hollers in Tennessee!
John Codman
- Last Name: Codman
I agree that the modification is ingenious, but their have been literally millions of Model Ts that ran fine without it. I cannot help wondering if you are putting a band-aid on the actual problem?
What defect inspired this unorthodox "upgrade"? What is it meant to solve?
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Based on the thread so far, the T in question is a Depot Hack, and therefore is not stock from the get go. If the gas tank is in a custom location, maybe lower and/or farther back, the gravity feed is less effective while going up inclines, leading to common fuel starvation. Many folks go with a modern electric fuel pump (my ‘27 runabout with the gas tank under the trunk has one), but the OP wanted to try something else. Nobody seems to question if a speedster uses a hand pump to solve the same problem.
If this is working, good for him.
Keep crankin’,
Eric
Keep crankin’,
Eric
tman1913
- First Name: Mike
- Last Name: Bender
- * REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Sometimes you got to do what you got to do!
Regardless of the cause, of the issue, the solution resolved it.
Good job.
Good job.
NoelChico
- First Name: Noel
If I remember correctly, Rod's tank is mounted further back on the frame. Noel
You may recall 15 T sedans had the tank under the back seat. Early coups had the tank in the trunk. The solution was to lower the carb with a special, longer/lower intake manifold. I have done this for 2 T's with model A carbs. (lowered the carbs) Works well.
Pressurizing the tank is a solution. Better than a fuel pump that will fail regularly IMHO. Thats been my experience.
So I shy away from electric pumps.
I have heard of pressurizing the tank in a similar fashion, but I dont think a check valve, pressure gage, or spark arrester was used.
Two of my T's have the fuel tank mounted in non-standard locations, both decided by the state Ford agents and distributors for their respective colonial bodied cars. My 1924 Tarrant special tourer has the tank suspended on the original brackets UNDER the spare tyre carrier at the back. It is fitted with a Stewart vacuum tank to draw the fuel to the carburetor, just like Dodges have.
Duncan and Fraser went a different route with my wide body roadster. With a lowered steering column and front seat, the fuel tank was shifted to the front of the integral turtledeck and raised some 7" higher than standard.
One thing they have in common is a 5/16" fuel line. That delivers some 35% more fuel than a 1/4" line.
Randall strickland
- First Name: Randall
- Last Name: Strickland
If you live in the mountains and everywhere you go is up hill or down this will fix your gas starving, I did this around six years ago after talking to and seeing George's https://youtu.be/smymG4xlRcU?si=YIq5Y6lEAVcvrkqu.
The 1\8 vent elbow line swivel's when removing cap
Randall strickland
I also have 5/16 gas line , didn't help me going up steep mountains.
Regardless of fuel line size, you are always restricted by (A) head pressure, and (B) orifice size (float valve orifice). You can run a fire hose from your tank to your carb, and you are still trying to flow through the same tiny hole in the carb. Increase fuel line diameter may let you sleep better but by itself, at the exceedingly low pressures we're dealing with, it will not dispense more fuel into the carb by any practical measure
Increase the fuel pressure and you will deliver more fuel to the carb through any given orifice
Increase the orifice size and you will deliver more fuel to the carb with any given fuel pressure
Assuming an original float valve orifice of .125" and (for instance) head of 6", CD of 1 (and water for the purpose of easy calculating) you will deliver .217 gpm at atmosphere
Assuming present commercial float valve orifice of .093" and all the same parameters, you will deliver .120 gpm at atmosphere, so there is your inability to climb hills...you have cut your fuel delivered to the carb in half under all other conditions or variables
calculations for gasoline vs water will show a difference of gpm for gasoline, but those values will still show delivered gpm to be 1/2 at orifice of .093 vs .125 for any given pressure
you have to raise the head to 19.5" when using the .093" orifice to achieve equal liquid delivery as .125" will deliver at a 6" head
either a pressure increase or an orifice increase will solve the fuel starvation problem...and Rod increased pressure (which was nicely executed)
Fun Facts:
Fun Facts:
- 1 PSIG at the fuel tank is the equivalent of having a 36" head pressure which is like mounting your tank nearly on the roof of the car
- added to orifice size variable, is "turbulence" which is caused by both orifice size and obstructions beyond the orifice (think "needle")
Rich Bingham
- First Name: Rich
- Last Name: Bingham
Thanks for an informative reply, Scott ! Much appreciated !!
"Get a horse !"
Rod
- First Name: Rod
Scott,
I very much appreciate your scientific approach to this problem. Thanks for adding to this conversation. Facts always triumph over opinions.
Rod
Rod
Thank you, Scott!
NoelChico
- First Name: Noel
Thank you, Scott. I enjoy and pay attention to your science-based comments. I look forward to your knowledge shared with us. Noel
I have missed you Scott, and your informative posts!
A lot of high end expensive automobiles of the 1910s used exhaust pressure to pressurize the fuel tank and deliver gasoline from far back and/or low level gasoline tanks up to the front. I do not think I have ever heard of one exploding or causing any sort of fire.
Your installation is very neat, and appears practical. Using the check valve (or one way valve) is a good idea, especially on such a short fuel line. Ambient temperature variations otherwise could push some amount of gasoline or fumes forward in the pressure line and spill into the exhaust pipe. Even IF that were to occur (actually unlikely?), it most likely would not be hazardous since the pressure line is plumbed into the top of the gasoline tank. The only gasoline that could push back in the line would be a very small amount of splash that might enter the line when the engine is being shut off (unlikely scenario). The small amount of fumes that could be blown back through the line would never be enough to become explosive in the exhaust line, and would naturally dissipate quickly. Regardless, a check valve adds a layer of security, peace of mind if nothing else.
Some era systems had a vertical loop of tubing in the pressurizing line. This acted as both a fluid and vapor trap as well as additional cooling for the hot exhaust gasses. It also added a layer of security as a sort of spark arrester. A lot of those considerations become moot points under normal use. Once the tank becomes pressurized, providing that the tank or lines are not leaking much, the actual flow of "hot" exhaust gasses is slow enough that more than a few feet of tubing will be cooled quickly enough such that the pressurized exhaust reaching the tank will not be hot enough to cause any harm, and any "sparks" that did manage to enter the line will be practically cold before it can reach the tank as nothing more than a piece of dust.
I have actually wanted to do this to one of my model T speedsters for many years, just never got around to it. I have built/restored and driven five speedsters so far. Three of them were pressurized by hand pumps, which I loved using! One, had a Stewart Vacuum Tank, which I also liked. The other was a simple vented gasoline tank and gravity.
It's also an essential item in order for the exhaust pressure system to function. Model N's used an exhaust pressure oiler, complete with check valves. They hold pressure so well, that if you don't purge the pressure after a run, it will continue to flow oil to the fourth main for some time afterwards and make a neat puddle on the driveway.Wayne Sheldon wrote: ↑Tue May 20, 2025 6:59 am
... a check valve adds a layer of security, peace of mind if nothing else.
jab35
- Last Name: Bartsch
There's a reprint of a 'Tinkerin Tips' article on Model T fuel systems and fuel starvation in the current Vintage Ford (May-June 2025) pp38-41. A DIY exhaust gas fuel pressurization system is described along with a parts list. Just fyi, jb
