drag link question
Last Name: Hjortnaes
drag link question
Post by DHort » Sun May 18, 2025 11:52 pm
I just noticed that my two T's have different connections at the draglink/pitman arm connection.
Which is correct? Bolts and safety wire, or nut and lock washer?
First Name: Keith
Last Name: Townsend
Re: drag link question
Post by KWTownsend » Mon May 19, 2025 12:15 am
Neither.
Castle nuts and cotter pins.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Mon May 19, 2025 12:34 am
Hi Dave, I think what Keith meant was. Bolts long enough to install castle nuts & cotter pin.
Craig.
Post by Allan » Mon May 19, 2025 3:15 am
Bolts, castle nuts and split pins, just like the pan bolts.
Post by DanTreace » Mon May 19, 2025 7:56 am
As posted, use bolts, castle nuts and cotter nut to bolt end. The bolts pass into the cap but will thread into the drag link. The nut and cotter keeps bolts in place.
(Anti-rattle spring is accessory)
