original 1909 sales booklet
ModelT46
Topic author - Posts: 1664
- First Name: Darel
- Last Name: Leipold
This isaa from my collection. An original 1909 sales booklet .
- Last Name: Patrick
Re: original 1909 sales booklet
You can remove that old tape with Naptha (aka lighter fluid) without damaging, or discoloring the paper. Put on enough to get under the tape and let it do its’ work. No need to rub. After short time the tape will easily come off. Don’t hurry it or try to remove prematurely. May require several applications as Naptha evaporates quickly. You might want to lightly and gently rub to remove any remaining adhesive after the cellophane has been removed.
varmint
- First Name: Vernon
- Last Name: Worley
I wonder if page eleven implies that Ford will also sell a chassis if you request one.
Vern (Vieux Carre)
Kevin Pharis
- Last Name: Pharis
Too bad ‘ol Henry went away from that stately winged radiator logo
