Did this carbide generator blow up?
Topic author - Posts: 1709
- First Name: Herb
- Last Name: Iffrig
It is a side mount type of generator. Holy cow, what happened to it?
Is it just showing the effects of age and brass cracking from the spinning process? I have seen other pieces of brass get this way, but not to the extent this one has suffered. It looks shredded.
- First Name: Keith
- Last Name: Townsend
Re: Did this carbide generator blow up?
Herb-
I believe that is the effect of 100+ year old spun brass that has been exposed to the elements.
The upper chamber is the water reservoir. The lower chamber would have had the acetylene gas.
Keith
Keith
- First Name: Greg
- Last Name: Griffin
- * REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Notice the presence of a valve where the hose would connect to the generator. I suspect that the generator was "shut off" by stopping the water drip and immediately closing the valve, which would bottle-up the gas still being generated by the still-wet carbide. The generator probably burst, not exploded.
Doesn't explain burst top tank, though.
It's all due to stress corrosion cracking in cold worked brass.Greg Griffin wrote: ↑Fri Jun 20, 2025 2:53 pmNotice the presence of a valve where the hose would connect to the generator. I suspect that the generator was "shut off" by stopping the water drip and immediately closing the valve, which would bottle-up the gas still being generated by the still-wet carbide. The generator probably burst, not exploded.
- First Name: Keith
I don't know what brand of acetylene generator is pictured, but on the E&J generator for my 1911, when the water valve is turned to the "off" position, it opens a port to vent the acetylene in the bottom of the tank to the outside.
- Last Name: Tannehill
Herb I think you have what is left of an early Jno Brown generator judging by the wing nut locks.
- First Name: Bill
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
I would go with Keith's response. Too little cold working in spun brass dents easily. Too much cold working in spun brass invites significant cracking with time. For my 2 cylinder Buick I managed to buy new spinnings a number of years ago but needed the hardware (They are Gray and Davis bullet lights). I purchased a set of lights properly represented as only good for hardware. When I opened the shipped lights in a box I just laughed and exclaimed that they looked like cherry bombs had been set off inside each light looking much like the pictured generator.KWTownsend wrote: ↑Fri Jun 20, 2025 10:11 amHerb-
Keith
