Seng Accessory locking steering wheel.
Dennis Fleming
Topic author - Posts: 254
- First Name: Dennis
- Last Name: Fleming
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
I am in search of the horn ring that is suppose to be with this steering wheel. I have the complete wheel and fixtures including the bracket that houses the horn ring and mounts to the steering gear box. I have the keys and everything works great. Anybody have a spare horn ring or at least a good photo of the ring. May be able to make it.
Re: Seng Accessory locking steering wheel.
Do a search of "mtfca: Seng steering wheel". You should find posts made here and other places with many images. I just did and got a lot of returns some which show the back side of the steering wheel.
viewtopic.php?t=20630
There are links in that post with more photos.
Suggest test fitting what you have and see how you like it. As I said in my post/reply it was just too big for my application so sold it.
Rich in Colorado
- Last Name: Carlson
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door 1923 Touring
Here is what I have when I had it out to restore the wood, before I painted the metal parts. I also found the patent for the horn ring with diagrams. I am traveling now and could get a picture of the back when I get home later this week. I don’t have the fixture that is under the ring so my horn ring doesn’t work. Looks like you have that part.
I just liked the look of the wood and use a normal horn button on the steering column.
Rich in Colorado
1922 Model T Center Door
1923 Model T Touring
1928 Model A Tudor
1956 Ford Thunderbird
1966 Ford F250 Camper Special
1928 Model A Tudor
modeltspaz
- First Name: Mike
- Last Name: Spaziano
Just a little information. Originally, the stamped spider was painted wood grain.
Mike.
Mike.
