Timing issue
Jlenon
First Name: Josh
Last Name: Lenon
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Timing issue
Post by Jlenon » Fri Jul 25, 2025 7:00 pm
I’ve been having some issues with my T — you can check my last post for the full story if you’d like — but I feel like I may have finally pinned it down (at least I hope so).
I decided to check the timing, and when I brought cylinder #1 just past TDC, there was no spark there. Instead, cylinder #4 was sparking. So I took apart my new Day timer and saw that the brush is in the bottom right corner, making contact with #4, instead of being in the top left, making contact with #1.
I then checked the timing gear to make sure the timing marks were lined up — and they were.
So now I don’t know what to do, lol. I can’t change the brush position because of where the pin goes that holds the timer housing on. So I’m stumped for now.
Any help is really appreciated — thank you guys in advance!
Re: Timing issue
Post by speedytinc » Fri Jul 25, 2025 7:05 pm
You dont happen to have an early cam with the pin hole thru? That would put you out 180 degrees.
Are you really @ tdc #1?? Make sure both valves are closed as you reach TDC.
Intake just closed & exh is about to open.
Last Name: Juhl
Re: Timing issue
Post by Oldav8tor » Fri Jul 25, 2025 8:11 pm
John has the answer I believe. I've seen this many times. My 1917's camshaft is that way. I put a small mark on the end of the camshaft showing the correct alignment to reduce the risk of installing it 180°
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: Timing issue
Post by rickd » Fri Jul 25, 2025 8:19 pm
Repeating what these guys just told you in a different way. Make sure #1 piston is coming up on the compression stroke then check that your commutator roller or flapper is near the #1 post. Then set your timing.
Re: Timing issue
Post by Jerry VanOoteghem » Fri Jul 25, 2025 10:08 pm
There's the key words in this sentence...
Jlenon
First Name: Josh
Last Name: Lenon
Re: Timing issue
Post by Jlenon » Sat Jul 26, 2025 2:09 pm
My pinhole on the cam doesn’t go all the way through I swish it did that would make things a whole lot easier the brush is 180 no matter what I’m thinking I can maybe just put the wires on the timer or the coils backwards from what they should be for an easy fix
Re: Timing issue
Post by Scott_Conger » Sat Jul 26, 2025 3:19 pm
You've convinced yourself that a car that previously ran, but with a miss on #1 has now suddenly completely flipped the firing from #1 to #4 when at TDC...hmmmmm.
I'll reiterate what a few astute people have already stated, but in different words: This is a 4 stroke engine, meaning that each piston reaches "TDC" twice during each complete cycle. You have obviously mistaken #1 TDC exhaust for TDC ignition...and as a result, you are finding #4 throwing a spark when you are absolutely convinced it shouldn't. If #1 is at TDC of exhaust stroke, #4 absolutely WILL be throwing a spark.
I'll submit that everything is very likely fine with respect to this "issue".
If your car went from "running" to OMG EVERYTHING"S SCREWED UP!!! then I think you're simply investigating a simple issue without fully understanding how things work. That's OK. We've all been there. Invest in the FORD Service Manual, study it, and figure out what the root cause of your trouble is. If it ran once, your trouble is certainly not going to lurk within the timing gears or any other mysteriously hidden corners of the car, so do yourself a favor and stop pulling random things off of the engine, especially when someone eventually says "take the head off and have a look around!"
FORD made 15 Million Model Ts and at the present time, there are at least twice that many experts, so if you're looking for opinions, you'll get them. Read the manual, think about your problem, and resist the urge to follow down every Rabbit Hole people will inevitably point you toward.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Timing issue
Post by big2bird » Sat Jul 26, 2025 3:51 pm
.....and resist the urge to follow down every Rabbit Hole people will inevitably point you toward.
THIS ^^^^^
I cannot tell you how many times a thread on Corvette Forum starts with a bad plug wire, and by the end everyone says pull the engine.
It's just something stupid simple as Scott said.
Re: Timing issue
Post by Allan » Sat Jul 26, 2025 8:43 pm
Jeffrey, what else would you expect from Chev owners?
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Re: Timing issue
Post by michaelb2296 » Sat Jul 26, 2025 9:28 pm
@allan :lol: You asked for it, you got it, “T”. That’s all i got! :lol:
Adam
First Name: Adam
Last Name: Doleshal
Re: Timing issue
Post by Adam » Sun Jul 27, 2025 11:51 am
Did you re-wire your car or change your plug wires or rebuild your coil box and put things back together incorrectly perhaps? As you are sitting in the drivers seat, coil # 1 is on the right and coil # 4 is on the left…
Re: Timing issue
Post by speedytinc » Sun Jul 27, 2025 1:47 pm
Your previous post claimed you were running a roller timer. Now you have a new day. Changing to the newday requires a reset of the timing. brush/roller/contact timing is very different between the 2. Thats done by a rebending of the timer rod.
That & I believe you are not actually looking & tdc on compression stroke may be the issue.
RGould1910
Last Name: Gould
Re: Timing issue
Post by RGould1910 » Sun Jul 27, 2025 3:41 pm
"FORD made 15 Million Model Ts and at the present time, there are at least twice that many experts,"
That was a good one!!
J1MGOLDEN
Last Name: Golden
Re: Timing issue
Post by J1MGOLDEN » Sun Jul 27, 2025 4:55 pm
Some New Day Timers have a number by each terminal and the numbers are just going around like clock numbers and they will cause you to put the wires in the wrong order.
1 and 2 might be right or 3 and 4 might be wrong.
Re: Timing issue
Post by RajoRacer » Mon Jul 28, 2025 12:04 pm
FYI - firing order is 1,2,4,3 going c.c.w. on the timer but as John mentioned, standing at the radiator, #1 is on your left & #4 is on your right.
Re: Timing issue
Post by Jerry VanOoteghem » Mon Jul 28, 2025 12:05 pm
Have we scared off the OP?
