Steering Stabilizer Springs
Topic author - Posts: 11
- First Name: Stephane
- Last Name: Lezzier
- * REQUIRED* Type and Year of Model Ts owned: Touring US 1918
- Board Member Since: 2022
How instal the steering stabilizer spring on the right side on the front axle ? because the axle of steering hinder
Look 2 pictures of my car right and left and 1 picture of my parts
Re: Steering Stabilizer Springs
Here's how they did it https://www.mtfca.com/discus/messages/2 ... 1355089979
The "long ones" come in many different ends but install the same way
Those do not actually do very much to help with the steering. Mostly, what they do is if bushings and pins are loose, they reduce the intensity of the rattles. In some cases they might help steady things a little bit.
Bonjour.
Bonjour.
- Last Name: Humble
Not a steering stabilizer. Not a Ford part. Of the 15 million model T's, none left the factory with those installed. It will not improve driving or fix anything. Snake oil.
- First Name: craig
- Last Name: leach
Some times we forget that the band-aid, bubble gum & hay wire fixes for model T fords was what blossomed into the aftermarket industry
that we have now & that's the reason we can buy the parts we need to restore & repair our T's today. Ford gave birth to a industry that he
hated & the ironic thing is it outlasted the model T but keeps them going still. Imagine a world today that you had to go to the manufacture
for repair & replacement parts?
Those are all band-aides to get around properly rebuilding a front end.
Last edited by Jerry VanOoteghem on Fri Aug 08, 2025 2:37 pm, edited 1 time in total.
- Last Name: Codman
I agree with those who say that they are a band-aid. If there is something loose enough to cause steering issues, the looseness needs to be addressed, not covered up.
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
There was a pair of those on my 27 Touring when we bought it in the early 60's from the original owner. Removed them, fixed anything that was worn and all has been good ever sice. One of the many items sold to Model T owners to patch up real or imagined problems.
- First Name: Erik
- Last Name: Johnson
Those are anti-rattlers. They are a band-aid for worn steering components (bushings, tie-rod bolts, kingpins, etc.) but don't actually cure anything other than reducing noise.
They are one of the worst things you can install on the front end of a Model T Ford.
They create wear marks on steering system components, such as the spindle arm and tie rod. Over time, they can create deep grooves.
Erik Johnson wrote: ↑Fri Aug 08, 2025 6:39 pm
I think twice I have seen front axle assemblies that had grooves worn so deeply that the tie rod broke!
I had a spindle arm that was worn a quarter of the way through one side (less than an inch from the tie rod pin). One of the few original model T parts I sent to the scrap pile.
Yes they are an interesting bit of history. Really best to not use them on the car. They make interesting wall hangers and conversation pieces.
