14 Runabout progress
Topic author - Posts: 495
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
The bodywork on my 14 Runabout is almost finished and shoulld be ready to paint in the next couple of weeks. The body had a nasty patch on the back coverering a big rust hole and several subpar patches along the bottom under the door and on the driver side.
- First Name: Keith
- Last Name: Townsend
Re: 14 Runabout progress
Looking good!
Black primer?
Black primer?
- First Name: Art
Keith, Yes on the black primer as the car will be dark blue. I can't decide between your DB332 OR Russ's DB904. I want it to look like this picture. I think it may be closer to the DB904? Art
- Last Name: House
I zoomed in to see a really nice professional grade repair in that bottom rear panel. Good job Art.
Coming along nicely !!
- First Name: Art
- First Name: Art
- First Name: Art
Here are some pictures of the painted body using the DB904 color. Art
- First Name: Tom
- Last Name: Rootlieb
Looks good and I like the blue color.
- First Name: Gregory
- Last Name: Hammer
- * REQUIRED* Type and Year of Model Ts owned: 1914 Runabout Project
Art, very happy to see the amazing progress on this Roadster! I'm convinced it went to the right home! Great work!
It looks very good! You really know how to do a good repair and paint job. And you have an original body, not a reproduction! I restored one Model A many years ago. Then I did two Model T's. One thing I learned the hard way is not to take shortcuts. At first I thought that the finish coat would fill in the imperfections in the preparation. That was a big mistake. I also shimmed up the body from the bent chassis. Also a big mistake. I found that the car pulls to one side and I have to steer to one side just to keep straight on the road! Next one I did I checked out the chassis and got it straight first. Then I worked on the body. I got the filler as completely smooth as I could then put on primer and got it smooth first before putting on the finish coat. Came out much better. And the car runs straight on a flat road! Your car looks beautiful.
- First Name: Art
I have been dry fitting the fenders and running boards. I also started on the upholstery. Art
- Last Name: House
Don’t forget - like I did - to cherry stain the firewall
- First Name: Art
I got that!George House wrote: ↑Sat Aug 16, 2025 9:04 pmDon’t forget - like I did - to cherry stain the firewall(
