Jay Leno Model T Video
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Mon Aug 18, 2025 3:29 pm
Today’s release on Jay’s YouTube channel had him teaching one of his producers how to drive a model T. While many will disagree with his methodology, I have to admit that it is a real nice car.
Andy
Moxie26
Last Name: Jablonski
Re: Jay Leno Model T Video
Post by Moxie26 » Mon Aug 18, 2025 5:17 pm
Daisy Mae
First Name: Kurt
Last Name: Andersson
Post by Daisy Mae » Mon Aug 18, 2025 11:57 pm
What car guy doesn't love Leno....
Nice video, despite some cringe worthy statements/actions...
WillyR
First Name: Vilhelm
Last Name: VonRaschke
* REQUIRED* Type and Year of Model Ts owned: 1924 coupe
Post by WillyR » Tue Aug 19, 2025 10:20 am
needs the lay the hell off the hand brake.
EDIT: I see Jay used it as a training tool, and got him away from it quickly enough.
otherwise it's good for the continuation of future generations.... I like Jay's videos
I have been planning to make my own overall video, maybe I'll make a model T overview AND a driving video.
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
fireheadman
First Name: Ben
Last Name: Piraro
* REQUIRED* Type and Year of Model Ts owned: 1911 Model-T Pie Wagon
Post by fireheadman » Tue Aug 19, 2025 11:16 am
bookmarked that video... 2 cool things together right there!
Thanks for posting the link to it.
I'm about a month out from being in that seat, just waiting on some parts.
Question: Without a Ruckell Axle and in Colorado (high altitude), what would the estimated top speed be for a Model-T?
Member: Mile High Pedal Pushers - Denver, Colorado Chapter
Post by Jerry VanOoteghem » Tue Aug 19, 2025 11:50 am
I can't speak for the effects of altitude on top speed, but I can tell you that a Ruckstell does not make a T go faster. It's not an overdrive. It gives a low range, like having a 2nd gear, to enable climbing grades without using low pedal.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Aug 19, 2025 12:06 pm
Just one of a few of Leno's Faux pas.... calling the rux an overdrive...
BobD
First Name: Bob
Last Name: Doris
Post by BobD » Tue Aug 19, 2025 12:14 pm
Enjoyed the video. A lot of cringe worthy moments. :shock:
fireheadman
First Name: Ben
Last Name: Piraro
Post by fireheadman » Tue Aug 19, 2025 4:04 pm
thank you for the clarification.... that might be helpful in a few areas out here.
I'll save it for a future upgrade once the basics are in place and working as expected
Post by Steve Jelf » Tue Aug 19, 2025 4:56 pm
I watched until they got into the cringeworthy cranking, then I bailed. Jay said a Model T is an easy start, and it should be, but that one was stubborn. Probably because people were watching. :)
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Wed Aug 20, 2025 6:53 pm
For someone wanting to learn to drive a model T, Mitch Taylor has a much better tutorial video. In any case, there’s a LOT of practice required to develop the muscle memory to drive one smoothly and safely.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Post by Will » Thu Aug 21, 2025 1:28 pm
I would like him to put up a revision on how to hold the crank starter before someone gets hurt.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Post by speedytinc » Thu Aug 21, 2025 2:03 pm
His T shouldn't be so hard to crank. There is a clutch/linkage issue.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Aug 21, 2025 2:26 pm
Every Model T his to video I have seen has “issues” in my opinion. The difference is a lot more people will see this one. If it draws attention to our hobby, so much the better. The pluses outweigh any miscues.
Andy
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Aug 21, 2025 2:26 pm
Hey guys,
Keep in mind that this video, and the entire "Jay Leno's Garage" series, is created for it's entertainment value. These are not really intended as instructional videos. As referenced by previous posters, there are better instructional videos available for those that are trying to learn. This video looks to be Jay's version of the conversation that we all have with the public in grocery store parking lots. Because he's got a crew, cameras, and plenty of time to put out a polished product, his "introduction" to Model Ts is more in depth than our parking lot explanations, but the intent is the same, just expose folks to some, not all, of the idiosyncrasies of our beloved Ts.
Keep crankin',
Eric
Post by TXGOAT2 » Thu Aug 21, 2025 2:29 pm
"Question: Without a Ruckell Axle and in Colorado (high altitude), what would the estimated top speed be for a Model T?"
Same as one without on a downgrade. On a steep downgrade, about any Model T with an engine in it will go way over 50 MPH, which is too fast for a stock engine without overdrive. Speed going uphill depends a lot on the condition and body type of the car. A Ruxtel or other auxiliary gearing can be a big help on steep upgrades. There is a formula for how much power is lost per 1000 feet of added elevation. I think it's 3% per thousand, maybe 5%. High elevation reduces available oxygen in the air and lowers the engine's compression. It can also reduce the cooling system's ability to get rid of heat. Headwinds and tailwinds can have a substantial effect on the car's performance, especially a headwind on a long steep slope. If I drove a lot in mountain country, I'd want a KC Warford transmission, a Prus head, and some auxiliary brakes. I'd want to avoid carrying any needless weight. Weight works against both grade climbing and braking, so the less the better.
Post by TXGOAT2 » Thu Aug 21, 2025 2:33 pm
Thin, high mountain air will reduce both your engine braking and your aerodynamic drag, so be extra cautious when making steep descents at high altitudes. Be wary of brake fade. It's very real, and it can be deadly.
Post by speedytinc » Thu Aug 21, 2025 2:39 pm
The Montana boys AVERAGE 53mph. Average. That includes thru towns @ 25mph. Down hill, 70 mph is common. These are "stock" engines.
The speed of a model T depends on its horse power & tune. So 8-55mph? up hill, depending on the grade.
Moxie26
Post by Moxie26 » Thu Aug 21, 2025 5:42 pm
Speedytinc and Txgoat2 .... Your responses sound more like artificial intelligence. . really ?????
Post by TXGOAT2 » Thu Aug 21, 2025 5:48 pm
How so? Heck, I don't even have a cell phone. But when I was in school, they taught me to READ. That gave me ready access to thousands of years of accumulated knowledge from countless sources.
Post by speedytinc » Thu Aug 21, 2025 5:51 pm
I expect no less from you.
Moxie26
Post by Moxie26 » Thu Aug 21, 2025 7:35 pm
Nor I from you
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Fri Aug 22, 2025 2:22 am
@Steve (Jelf), if you look in the comments, I have linked to your video showing how to start a '15 Model T :-)
I for one enjoyed the video and Jays approach is much the same as I follows when I teach someone to drive the T. I just hate those videos that instructs to use the handbrake to go from low to high. My theory is that it originates from a guy at Ford Motor Company in UK, who use that approach. Many of the ones doing that on instruction videos may have learned driving T by that fellow at FMC.
I have however learned that it may be helpful to pull the hangbrake halfway (neutral) when reversing :-)
Regarding their trouble getting it going: I think they just fumbled too much with the choker so it was drowned. My ´14 is handcranked only and most times it starts right up, but sometimes it just wont until many pulls or a push of the car. I think they had a similar moment in the video.
Ford Model T 1914 Touring
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Post by Loftfield » Fri Aug 22, 2025 7:27 am
How fast will your Model T go, 40mph, 45mph, 50mph? Doesn't matter because you only have brakes for 32mph. The real question is not how fast will it go but fast will it stop!
