Changing a Ruckstell axle tube
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Thu Sep 04, 2025 11:51 am
I have a Ruckstell assembly that I am “refreshing “
When I assembled it a number of years back, the axle tube was severely bent, I opted to try the heating and shrinkage method. This did move the tube , however not far enough so I straightened it in a hyd press,…. Turns out this a mistake.
Initially it brought the axle tube into alignment for a while.
After a few years the axle seal started leaking, upon investigation it seems the axle tube was misaligned once again.
So this time I decided to replace the axle tube , using one that was from a non Ruckstell differential, which I shortened and hot riveted to the Ruckstell housing.
Turned pretty good, although I am concerned about potential oil leaks around the new rivets. Thinking it would be best to seal from the inside of the tube.
I am considering using RTV sealing, but has anyone out there gone down a similar route?….maybe there is a better product??
Dave
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Re: Changing a Ruckstell axle tube
Post by Shannon_in_Texas » Thu Sep 04, 2025 12:31 pm
Maybe paint the inside with Glyptal?
Post by speedytinc » Thu Sep 04, 2025 12:51 pm
Consider green (wicking) locktite.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Thu Sep 04, 2025 3:12 pm
I would be tempted to braze them like the oil pan.
Last Name: Tannehill
Post by JTT3 » Thu Sep 04, 2025 9:44 pm
The inside needs to be oil free for best adherence, that said Red Kote once cured works very well. Best John
Post by Allan » Fri Sep 05, 2025 1:57 am
if you change tubes, be a ware that the rivet holes in one pumpkin do not necessarily line up with those in another. It is best that you weld up and dress the holes in the donor tube. Then you can drill new holes using your centre casting as a template. Of coulse, you need to make sure you have the backing plate "clocked" correctly with the centre casting.
Dave1
Last Name: Eddie
Post by Dave1 » Fri Sep 05, 2025 7:48 pm
Allan, thanks for the tip, however I used as a doner a tube from a non Ruckstell . This required shortening of the tube, and of course drilling new holes
RGould1910
Last Name: Gould
Post by RGould1910 » Sun Sep 07, 2025 11:12 pm
A late friend used rtv to seal rivet holes on.a 12 rear end with new rivets. I did the same years ago. Kinda shade tree but no leaks.. I wouldn't braze or weld like they did in the fifties. Can warp the housings badly. I've seen it.
Post by Allan » Mon Sep 08, 2025 3:19 am
I'll second not brazing/welding. I had to do that on both castings on my 1912 van to fix cracks between the rivet holes. Both pieces needed to be machined true on the thrust faces and the joint between the two housings. To do this I had to make a spiggot to mount them on before fitting the whole to the lathe. It may not be such a problem with the later straight tube type axle housings.
Post by Mark Gregush » Mon Sep 08, 2025 12:58 pm
Wonder if this is something Chaffins to do for customers. I was going to contact them about installing a tube in a Ruckstell housing but never got around to it.
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Mon Sep 08, 2025 11:14 pm
I am not familiar with changing a t axle tube. Will this be a pressed fit that you will have to turn the tube down to get it to fit? If so here is a suggestion as I have changed many broken outer axle tunes on off road dump trucks..
If you have to turn the outer tube down to fit, turn it down so it is 2 thousandths larger than the hole in the pumpkin. Have the hole very clean. Have some timing marks on the outside of both parts, you can use a felt marker on the tube butscratch marks on the pumpkin or use a file corner on the edge of the hole. You can also put scratch marks on the tube. The a bx that is a little larger than the turned end of the tube and put the tube in it and put broken dry ice in it part way up the tube and let it cool down to shrink it. In the meantime when you are ready to press it in, take a torch and heat the tube area of the pumpkin to expand it. It does not have to be real hot but a little more than you want to touch. Line up your tube and press it in.
Measure and mark your depth before you start.
If you want to use a sealer that is up to you. You might want to put a little bevel on the end of the tube and when it cools use a oil resistant silicone in the bevel or a sealer of your choice.
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Sep 10, 2025 1:27 pm
I replaced an early backing plate on a Pertecto housing with a 26-27 backing plate. Very tight fit. Must be careful in your situation not to crack the housing when pressing the tube. Figure a way to support the housing from the inside so you're not pressing on the bolt ring. Also perfect alignment is critical so the radius rod lines up at the ball end of the driveshaft. I had no leaks without using sealant on this one..
Dave1
Last Name: Eddie
Post by Dave1 » Wed Sep 10, 2025 6:58 pm
The non Ruckstell axle tube is the same diameter as the OEM Ruckstell tube . The main difference is the non Ruckstell tube is longer. Not a huge job to shorten it.
It does take a lot force in a hyd press to insert the tube.
I made rivets and installed them hot.
Happy with the way it turned out.
Dennis_Brown
Last Name: Brown
Post by Dennis_Brown » Thu Sep 11, 2025 10:18 pm
Question, is there any type of thrust surface inside a left housing? I would have to go to the attic to look at one. if there is a thrust surface, would it be better to press there than against the outer bolt flange?
