Unknown Hub Cap Wrench
Post by Original Smith » Sat Sep 13, 2025 3:04 pm
This morning I went to my pile of hub cap wrench's and found one I'm not familiar with. I assume it's from the mid to late teens. It has an M with a diamond around it, and below that is a P with a circle around it. I'm guessing the P maybe Pruden, but have no idea about the M?
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Re: Unknown Hub Cap Wrench
Post by Tadpole » Sat Sep 13, 2025 3:36 pm
“M” in a diamond is Mossberg, do your research Mr. Smith!
Rajo23
Last Name: Goertzen
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Runabout
Post by Rajo23 » Sat Sep 13, 2025 5:28 pm
Mr. Smith is doing research, by simply asking this question.
Post by John kuehn » Sat Sep 13, 2025 6:52 pm
Here’s a lot of information about the Mossberg company. According to the information they were a large early tool company with lots of different tools. http://alloy-artifacts.org/frank-mossbe ... #auto-spec
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sun Sep 14, 2025 8:54 am
Many people don't do research, Larry is not one of them.
Post by DanTreace » Sun Sep 14, 2025 12:10 pm
Research is the best way, always learning in that process.
This Chart on the Hub Cap wrench history is helpful when searching swaps for the more correct factory tool set for specific years, yet sure that there was overlap and many different mfg. sourced by Ford to obtain 15 million # 1349 wrenches !
My favorite is the last version, that has the flanges or lugs around the opening for the front axle bearing collar, sure helps to "tune in" that tapered bearing to the race.
This one has mfg mark, found it to be Weston Mott.
Weston Mott.jpg (26.46 KiB) Viewed 281 times
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Sun Sep 14, 2025 12:46 pm
Was there a TT version that didn't have the T axle nut hole?
Post by DanTreace » Sun Sep 14, 2025 3:33 pm
Nope. T and TT use the same hub cap wrench, cap hex fits both, the TT cap is larger, but same hex.
There is TT-5893 Wrench, used for cyl. head bolt, spark plug, and the TT rear wheel rim nut. Replaces the std. T-2335 spark plug, cyl. bolt wrench.
The record of change on earlier designs note for rear axle nut. Guess you could as hex is same, but short leverage with that wrench. I use mine for oil pan hex and diff plug hex when on the road carrying factory tool kit.
Post by Allan » Sun Sep 14, 2025 6:44 pm
The axle nut hole is a poor afterthought. Many such wrenches show this to be butchered. There is no way it is actually fit for stated purpose, given the load expected to be applied to the axle nut. It does make a good tool for removing the hex drain plug on the pan though.
