Blockley tire update
Last Name: Hatch
Post by Dan Hatch » Thu Sep 11, 2025 9:18 am
FYI there is a tariff with Blockley tires.
They don’t charge you, you get a bill from shipper.
Still competitive with the other tire companies. Dan
Re: Blockley tire update
Post by TXGOAT2 » Thu Sep 11, 2025 9:23 am
Tire expense ought to be considered on a cost per mile of service basis. A quality tire that performs well over a long service life is a bargain, even at nearly twice the initial cost of an inferior tire.
Last Name: Hatch
Post by Dan Hatch » Thu Sep 11, 2025 9:26 am
That is why I am going to Blockley tire or as they say tyre.
Anything is better than what I have now on my Roadster pickup.
I just was giving anyone else a heads up. Dan
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Thu Sep 11, 2025 9:36 am
Mine have been stuck in Kentucky since Friday. Have yet to hear about a bill.
Last Name: Hatch
Post by Dan Hatch » Thu Sep 11, 2025 9:47 am
They are at the “gov wharehouse”. You will get an email from UPS telling you how much they charge you. Can pay driver or by PayPal. They kept mine about a week and half.
Strange that I got one right away, but they held the other one hostage. I guess one escaped is became an undocumented immigrant or whatever they are called now???🥸
Last Name: Hatch
Post by Dan Hatch » Thu Sep 11, 2025 9:50 am
I did just order another one today and saw the price has dropped some. So if you are thinking about getting some, better look into it.
Post by Original Smith » Thu Sep 11, 2025 12:08 pm
Blockley did the right thing by making their tubes thicker. That's all. They refuse to remake the correct valve stems for these tubes, and can't even put a real rubber stem on them. The valve stems they are using are current valves that are the correct size for larger cars like a Cadillac. Not only that, because of the size they throw the wheels more out of balance than the correct size valve stem!
Post by TXGOAT2 » Thu Sep 11, 2025 1:33 pm
Stick-on weights will cure that.
bnchief
First Name: Steven
Last Name: White
Post by bnchief » Fri Sep 12, 2025 7:28 am
So buy what makes you happy myself i do not care i have their tires and tubes and like them but i am only interested in driving my car.
Playswithbrass
First Name: Peter
Last Name: McIntyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Speedster
Post by Playswithbrass » Fri Sep 12, 2025 8:05 am
Use balancing beads. They do work as claimed.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Fri Sep 12, 2025 9:46 am
I like my Blockley tires. I agree with Larry about the tube. It is pretty heavy at the stem. I balance my tire so it’s just a little more weight.
Andy
Last Name: Hjortnaes
Post by DHort » Fri Sep 12, 2025 12:28 pm
One of you that ordered some could post the cost to your location, so those of us that need knew tires could compare. i purchased 2 six months ago and i would like to see how much it has gone up
Last Name: Hatch
Post by Dan Hatch » Fri Sep 12, 2025 1:54 pm
If you go to the website and put what you want in you cart, you can get a quote for shipped to your door. Will NOT include the tariff. You get that after the shipment gets to US. That I can’t say what is. Mine was 120 for two tires.
Yesterday the price on website was 135 lb per tire. Down from 149. Cost to you depends on lb to dollars too.
Post by DHort » Fri Sep 12, 2025 6:26 pm
Thank you for the information Dan. As of today tires are L135. I sent in a quote and will respond tomorrow.
Will see if I can get a more compete answer tomorrow. Tubes were listed as L39..
Post by Allan » Fri Sep 12, 2025 9:40 pm
All things being equal, all BE tyres originating in Viet Nam, all new stocks should rise in price at the same rate when the new tariff sets in.
Post by DHort » Tue Sep 16, 2025 1:02 pm
Quote from Blockley arrived today, 9/16/2025.
135 Pounds/tire x 2 tires = 270 Pounds
Total cost of 405 Pounds or $553. (I assume shipping is 135 Pounds)
I did not ask what the tariff would be. $120 for Dan a few days ago.
Last Name: Hatch
Post by Dan Hatch » Tue Sep 16, 2025 1:46 pm
Shipping is high. But is high everywhere. I just ordered 1tire &4 tubes, shipping was 115 lbs. Won’t know tariff till they get here, hope it hasn’t gone up again. Dan
Post by Allan » Thu Sep 18, 2025 5:23 am
Shipping is high because things are no longer shipped! They come every which way that is quicker, and far more costly. Most stuff is air cargo, hence the cost.
