AC Brake Linkage
dr1960
Topic author - Posts: 155
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
AC Brake Linkage
Anyone have the Rich Baughman AC Brake linkage setup that would be willing to share the dimensions for the rods from the brake pedal to the bellcrank and the rods from the bellcrank to the brakes? Also, if you have the instructions that came with the linkage set?
David - Yukon, OK
Will
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Re: AC Brake Linkage
I will measure mine tomorrow morning for you.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Dodge
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
I'll look also. I was at Rich's place when he was getting ready to move. I got all the drawings, instructions and tooling to make a set for
my car.
Dodge
my car.
Dodge
dr1960
- Last Name: Ruedy
Rich's wife sent me a few pages of drawings but most of the detail was on how to make the bellcrank. I would love to have a full set of drawings and dimensions for the complete kit.
David - Yukon, OK
dr1960
- Last Name: Ruedy
Does anyone know if Daniel Bennett is still manufacturing the AC Brakes after Larrry Sidmore passed? I had his card from Chickasha 2 years ago. I have tried contacting him by phone and email from the ad i saw on the forum, with no response. Maybe i don't have current contact information. Any help is appreciated.
Thanks,
David
Thanks,
David
David - Yukon, OK
Shrshot
- First Name: Kent
- Last Name: Palazzo
- Board Member Since: 2024
Yes, David he is. I got mine from Daniel in late winter. He is kind of a hard fellow to get ahold of. I sent you a PM with his contact info....dr1960 wrote: ↑Tue Sep 23, 2025 9:34 pmDoes anyone know if Daniel Bennett is still manufacturing the AC Brakes after Larrry Sidmore passed? I had his card from Chickasha 2 years ago. I have tried contacting him by phone and email from the ad i saw on the forum, with no response. Maybe i don't have current contact information. Any help is appreciated.
Thanks,
David
dr1960
- Last Name: Ruedy
Thank you. That is the information i have been trying. I'll keep trying.
David - Yukon, OK
tiredfarmer
- First Name: leonard
- Last Name: simunek
David is still making them, but he is buzzy doing repairs for the farmers. This Fri and Sat he will be at the Fairview Threashing Bee.
dr1960
- Last Name: Ruedy
Still looking for help from anyone that has the Rich Baughman AC brake linkage that would be able to provide the dimensions of the rods and installation instructions.
David - Yukon, OK
AC brakes used a cable.
Larry
A-C did make a Heavy Duty set, with larger external band, special drum …. and used rods.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
That would be the cats meow. I have never seen one.
Thanks for posting that.
But - still for a small drum rear end !
namdc3
- First Name: Nikolaus
- Last Name: Martin
I've tried to convey this in the past, but to no avail. Here is another view showing that the rod version also has an equalizer to ensure both sides pull evenly.
Interesting.
I notice the rod clevises mount to a small plate that acts as an equalizer.
The secondary pull rod has a spring to remove the slack from the system.
