Battery
Re: Battery
There is a wide variety of small AGM non-spill batteries available. Generally speaking, the smaller the battery, the more quickly it will discharge at any given load, and the more often it will require recharging. Batteries do not tolerate being heavily discharged very well, so choose one that can carry the expected load for longer than you expect to need it to. My choice would be to select a larger battery over a smaller one. An inadequate battery will give inadequate service.
Re: Battery
The specification for your need is Ah ampere hours and one that can take frequent recharging. These are often sport or lawn&garden batteries
These are some examples &reputable places to get them if need be. There are others.
Re: Battery
The "motorsport" batteries are often very pricey. The larger, lawn tractor sizes seem to be more reasonably priced, and they have substantial terminals.
Re: Battery
What is a AGM battery?
- Last Name: Nunn
Re: Battery
Absorbed Glass Mat.
Re: Battery
Topic author - Posts: 167
- First Name: Ralph
- Last Name: Fitz-Gerald
Re: Battery
Thanks, always a great sources of information
Fitzy
Fitzy
- First Name: Jim
- Last Name: Davis
Re: Battery / Magneto charger
Charge it off the magneto with a diode and a tail light bulb. or buy the magneto charger kit from one of the vendors. Can also use it for coil power when cranking for more spark till you switch over to mag.
