Battery
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Battery
Post by Ralph F » Fri Oct 03, 2025 8:18 am
I would like to know what my option are for a small agm battery? I would use it for 3 led lights on my touring car.
Ralph
Re: Battery
Post by TXGOAT2 » Fri Oct 03, 2025 8:53 am
There is a wide variety of small AGM non-spill batteries available. Generally speaking, the smaller the battery, the more quickly it will discharge at any given load, and the more often it will require recharging. Batteries do not tolerate being heavily discharged very well, so choose one that can carry the expected load for longer than you expect to need it to. My choice would be to select a larger battery over a smaller one. An inadequate battery will give inadequate service.
Re: Battery
Post by TRDxB2 » Fri Oct 03, 2025 11:15 am
Ralph
The specification for your need is Ah ampere hours and one that can take frequent recharging. These are often sport or lawn&garden batteries
These are some examples &reputable places to get them if need be. There are others.
Re: Battery
Post by TXGOAT2 » Fri Oct 03, 2025 12:35 pm
The "motorsport" batteries are often very pricey. The larger, lawn tractor sizes seem to be more reasonably priced, and they have substantial terminals.
Re: Battery
Post by Original Smith » Fri Oct 03, 2025 1:30 pm
What is a AGM battery?
Mark Nunn
Last Name: Nunn
Re: Battery
Post by Mark Nunn » Fri Oct 03, 2025 4:27 pm
Absorbed Glass Mat.
Re: Battery
Post by TRDxB2 » Fri Oct 03, 2025 7:03 pm
https://www.interstatebatteries.com/blo ... gm-battery
Ralph F
First Name: Ralph
Re: Battery
Post by Ralph F » Sat Oct 04, 2025 4:14 pm
Thanks, always a great sources of information
Fitzy
Novice
First Name: Jim
Last Name: Davis
Re: Battery / Magneto charger
Post by Novice » Mon Oct 06, 2025 12:20 pm
Charge it off the magneto with a diode and a tail light bulb. or buy the magneto charger kit from one of the vendors. Can also use it for coil power when cranking for more spark till you switch over to mag.
