Could use your help - '27 coupe w/ Holley NH
Topic author - Posts: 58
- First Name: Mike
- Last Name: Sibley
- Board Member Since: 2025
The choke/mixture rod evidently was replaced with one that really does not fit this car as it is too long and sticks out of the dash about 4 inches.
I had the carburetor (bayonet type not t-top) rebuilt but I am having trouble with the choke/mixture operate the carburetor to operate properly. The location of the small holes where the choke rod attaches is on top of the input manifold, which makes it extremely hard to adjust the mixture. Also it does not have enough play to properly choke the carburetor.
I am thinking about extending the rod from the choke to a location that makes it easier to operate both functions. Would anyone have a photo of similar that operates properly? I would really appreciate it as I just have a wire between the choke on the carb to the proper location on the rod?
I've tried to find a shorter choke/mixture rod maybe more for this actual car but have not been successful.
Thanks,
Mike
Thanks,
Mike
- First Name: Mike
- Last Name: Sibley
Re: Could use your help - '27 coupe w/ Holley NH
PS - I'm trying to add a collar to put it above the intake but at that location it tends to hit the firewall not letting the rod pull enough distance to engage the choke properly.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Here is how it is done for the NH according to the Ford Service Manual.
- First Name: Mike
- Last Name: Sibley
Thanks! I am not an experienced auto mechanic but I am trying to learn. My wife bought this car for me and I am doing my best to get it up to snuff. I appreciate all your help.
- First Name: Vernon
- Last Name: Worley
Mike, I just had to deal with all this on our Coupe. I believe the two bolts mounting the carburetor to the intake manifold are 3/8". You may need to loosen them, rotate the carb. so that the screw closest to the engine goes up, and that the screw closest to you goes down. While holding the carb with some channel locks wrapped in a shop towel, hold it in this rotated position. Then with another hand use a 9/16" open wrench to hold the screw and with another hand/9/16" open wrench, tighten the nut. A little bit of rotation is magnified by the tall mixture adjustment needle.
I had gouges in the hot air collection pipe it was so close. I also, with a high speed mini grinder, removed 1/16" material from the hot air pipe where it contacts the exhaust manifold.
I also relocated the slider higher up on the choke rod by drilling holes to a new location.
The rod itself is sold longer than you need. The installer is supposed to cut it down to size. That is why it sticks out the dash. Ours no longer does stick out.
Vern (Vieux Carre)
If the combination mixture/choke rod was replaced, most likely with a repro, one drives out the tension pin holding the adjustment knob, shorten the rod as needed, reattach the knob, redrill the hole & reinsert the tension pin.
Ford supplied a "special" hot air pipe with indentation for the swivel top carburetors so as to not have that interference issue.
Check the parts book. There are seven different lengths of adjusting rods used. I went through that with my late 25, and had an interesting time trying to locate the correct length. Keep on trying.
For the repro needle valve, that replacement has longer arms or fingers than the originals (provides the tension on the round barrel to keep the needle valve in correct spot) can interfere with the hex portion and prevent full seating of the needle.
My fix is to cutaway a portion of those arms (neat job no, but results are right
)...... just another thing with repro parts. Cut back the arms improves function, be sure to crimp the arms just a bit to get the proper tension to prevent drift.
- First Name: Mike
- Last Name: Sibley
Thanks, I am learning so I appreciate the advice!RajoRacer wrote: ↑Tue Oct 07, 2025 11:13 amIf the combination mixture/choke rod was replaced, most likely with a repro, one drives out the tension pin holding the adjustment knob, shorten the rod as needed, reattach the knob, redrill the hole & reinsert the tension pin.
The adjustment rod on this car has a black Bakelite type knob on the top and I cannot seem to locate a set screw or anything to reattach it if I cut it. Also, when I set the fitting over the choke rod that pulls the choke, the rod wants to come out of the bayonet fitting. I am going out to work on the vehicle this morning so I will try to get it better using everyone's advice.
Sounds as though the P.O. did some "handywork" of his own - the knob coming out of the dash is/was aluminum and the square shank is quite long - I'll measure one today & post a photo.
- First Name: Mike
- Last Name: Sibley
Obviously, the previous owner put this in without using the correct part. Two issues, the knob at the top is not removable to allow me to cut the rod and replace the knob so I am ordering one from the parts suppliers that now love me! Photo is attached. The rod is 28 7/8 inch long.
I found a Model A repair manual in the car after we got it, so obviously this part might have been for a Model A.
The second issue is that the first hole in the rod is 4 3/8 inch from the tip which puts the gizmo that the choke connection attaches to which puts it in the center of the manifold. I need to either replace the whole thing with a new rod or drill new holes, cut to the right length and put a new knob on the top.
PS - the square portion of the rod is only 1 7/8-inch long.
The vendors sell a replacement that is long and you cut to length, the knob is held with a split type pin. That is what you need.The second issue is that the first hole in the rod is 4 3/8 inch from the tip which puts the gizmo that the choke connection attaches to which puts it in the center of the manifold. I need to either replace the whole thing with a new rod or drill new holes, cut to the right length and put a new knob on the top.
Perhaps your rod is for the Vaporizer Carb adj. rod and knob assembly, for the Fordor it's 29 9/16"
The rod for your 27 Coupe is either 4129F, 27 13/16" or the 4129G , 26 1/4" long and the square section is longer too.
Vaporizer rod shown in this photo, choke arm higher.
NH rod with choke arm lower on the rod. Rod shown is the vendor version, sometimes needs a bit of tweaking to the square shaft to slide easily in the square tubing. Filing a little. The goal is a nice fit, but keep from rattling too, the square end long enough to slide up for full choke movement, but not too far that the end of the rod pulls out of the square tubing.
- Last Name: Worley
If the square end is only 1-7/8" then someone cut the wrong end.
Vern (Vieux Carre)
