AC Brake Linkage
dr1960
First Name: David
Last Name: Ruedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
AC Brake Linkage
Post by dr1960 » Fri Sep 05, 2025 9:08 pm
Anyone have the Rich Baughman AC Brake linkage setup that would be willing to share the dimensions for the rods from the brake pedal to the bellcrank and the rods from the bellcrank to the brakes? Also, if you have the instructions that came with the linkage set?
David - Yukon, OK
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Re: AC Brake Linkage
Post by Will » Sat Sep 06, 2025 4:38 pm
I will measure mine tomorrow morning for you.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Post by Dodge » Sat Sep 06, 2025 5:56 pm
I'll look also. I was at Rich's place when he was getting ready to move. I got all the drawings, instructions and tooling to make a set for
my car.
Dodge
dr1960
First Name: David
Last Name: Ruedy
Post by dr1960 » Sat Sep 06, 2025 9:51 pm
Rich's wife sent me a few pages of drawings but most of the detail was on how to make the bellcrank. I would love to have a full set of drawings and dimensions for the complete kit.
David - Yukon, OK
dr1960
First Name: David
Last Name: Ruedy
Post by dr1960 » Tue Sep 23, 2025 9:34 pm
Does anyone know if Daniel Bennett is still manufacturing the AC Brakes after Larrry Sidmore passed? I had his card from Chickasha 2 years ago. I have tried contacting him by phone and email from the ad i saw on the forum, with no response. Maybe i don't have current contact information. Any help is appreciated.
Thanks,
David
David - Yukon, OK
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Tue Sep 23, 2025 10:11 pm
Thanks,
David
Yes, David he is. I got mine from Daniel in late winter. He is kind of a hard fellow to get ahold of. I sent you a PM with his contact info....
dr1960
First Name: David
Last Name: Ruedy
Post by dr1960 » Tue Sep 23, 2025 11:07 pm
Thank you. That is the information i have been trying. I'll keep trying.
David - Yukon, OK
tiredfarmer
First Name: leonard
Last Name: simunek
* REQUIRED* Type and Year of Model Ts owned: 1926 touring. 1931 model a pickup, 1947 willys cj2a
Post by tiredfarmer » Wed Sep 24, 2025 7:42 am
David is still making them, but he is buzzy doing repairs for the farmers. This Fri and Sat he will be at the Fairview Threashing Bee.
dr1960
First Name: David
Last Name: Ruedy
Post by dr1960 » Sun Oct 05, 2025 6:08 pm
Still looking for help from anyone that has the Rich Baughman AC brake linkage that would be able to provide the dimensions of the rods and installation instructions.
David - Yukon, OK
Post by Original Smith » Mon Oct 06, 2025 1:59 pm
AC brakes used a cable.
Post by DanTreace » Tue Oct 07, 2025 8:58 am
Larry
A-C did make a Heavy Duty set, with larger external band, special drum …. and used rods.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Oct 07, 2025 4:39 pm
That would be the cats meow. I have never seen one.
Thanks for posting that.
Post by RajoRacer » Tue Oct 07, 2025 6:09 pm
But - still for a small drum rear end !
namdc3
First Name: Nikolaus
Last Name: Martin
Post by namdc3 » Wed Oct 08, 2025 12:50 pm
I've tried to convey this in the past, but to no avail. Here is another view showing that the rod version also has an equalizer to ensure both sides pull evenly.
First Name: john
Last Name: karvaly
Post by speedytinc » Wed Oct 08, 2025 1:57 pm
Interesting.
I notice the rod clevises mount to a small plate that acts as an equalizer.
The secondary pull rod has a spring to remove the slack from the system.
