What have you done to/with your Model T in October?
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon Oct 06, 2025 12:37 pm
Filled tires to 34psi.
Changed the oil.
Cleaned the lower drain cock connections and put blue thread locker on the threads to cure a leak.
Achieved speeds over 20mph for 1st time.
Vern (Vieux Carre)
Re: What have you done to/with your Model T in October?
Post by TXGOAT2 » Mon Oct 06, 2025 1:11 pm
A '25 coupe ought to do 35 to 40 MPH on level ground with no trouble. (Or more)
That assumes all 4 cylinders are operating on a good fuel/air mix, that timing is correct for the situation of the moment, and that brakes and bands are not dragging. If you have "balloon tires", 28 PSI is plenty.
Post by TXGOAT2 » Mon Oct 06, 2025 1:14 pm
Too much oil in the crankcase will sap power. 1 gallon is usually too much on a refill. For a refill, 3 to 31/2 quarts ought to get the oil level up to the upper cock with the car sitting on level ground. According to Ford, "best results will be obtained with the oil level halfway between the upper and lower cock".
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon Oct 06, 2025 1:17 pm
Took advantage of the summer like weather here in northern Michigan to sandblast and paint 26-27 Ford accessory rear bumper brackets.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Oct 10, 2025 1:27 am
Lowered the tire pressure.
Drove 5 miles.
Watched it boil either from timing, lean carb or our poverty radiator or all three.
Learned several ways how to stop the thing. Have not tried the parking brake yet to stop it.
Tried driving with windshield open.
Choke wire came loose from rod. Fixed it.
Cronked horn at waving people.
Vern (Vieux Carre)
bobt
Last Name: Thompson
Post by bobt » Fri Oct 10, 2025 6:13 am
I suggest NOT using the parking brake to stop unless in an emergency. bobt
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Fri Oct 10, 2025 6:52 am
I finished rebuilding my rear axle, now to stuff it back under the car before Hallows
Kids (and some grownups too) like to sit inside with "Mr. Boneypants" and let either their parents or friends take their picture. ;)
Fun never quits!
Last Name: Strange
Post by CudaMan » Fri Oct 10, 2025 8:26 am
Did the fall oil change on my '24. Soon I'll be removing my warm weather air filter and installing the factory hot air duct to the carb. :)
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Oct 10, 2025 10:39 am
I hear you Bob, but are you also suggesting that I not even test (for some unknown reason to me) it to see if it will stop the car?
Vern (Vieux Carre)
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Oct 10, 2025 11:17 am
I had replaced the starting crank bushing on my 1915 a few years ago, but it creeps forward and has to be tapped back into place.
I pulled it most of the way out and added a Dutch knurl to it. I'll mix up a little JB weld to the outside of the bushing before pulling it back in.
Keith
Post by Norman Kling » Sat Oct 11, 2025 4:39 pm
I tried to start my 22 Runabout. It didn't start. I choked it and choked it and should had gas dripping out of the carburetor, but none. Then I checked the fuel level. The stick went all the way to the bottom of the tank. No gas at all. I only open that garage about once a month when I drive one of the cars to the museum for a couple hours. Last time I was out any longer was July 4 when I went to a parade. So didn't smell any gas or see any on the floor. So now I need to put some gas in it and check for leaks. I have 2 T's that run, and took the other one last time I had one out. The reason I tried to start it today, is that I sold one of my 3 T's and wanted to get it out so it could go to it's new home.The garage is detached from the house. So at least if It caught on fire, the house would not burn, but I would lose all my T's.
mikefr24
Last Name: Freeman
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring with Pickup Truck Bed Mod
Post by mikefr24 » Sun Oct 12, 2025 8:00 am
Fixed a leaking radiator.
Replaced the hand crank bushing. I made a puller to get it out.
Replaced a leaking gasoline sediment bowl and replaced all the gas line.
Next up - remove rear axle and rebuild it.
MotoBrew
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: Runabout 1927
Post by MotoBrew » Mon Oct 13, 2025 7:57 am
Re-adjusted the shape of the carb throttle rod (pull rod) to get full quadrant and carb throttle range. Wasn't getting the carb throttle more than 3/4 of WOT before and was completely closed with about 5°left on the quadrant. I am sure it will be picking up at least 1/2 HP from the adjustment...I better hold on!
Sorry all it has a dizzy.....for now. Checked the condition of the cap, rotor and points, re-adjusted the points to 0.017". I do have the original timer setup and seven coils in questionable condition. So am considering converting it back once I have gone through all the running gear to make it a good driver.
This winters plan is all about running gear, (replaced the front wheel bearings already and checked wear on front end parts). My plan is to go through (rebuild) the rear axle, drive shaft and add Rocky Mountain brakes. Basically make it safe, reliable and drivable so I can drive it more, just as my Grandfather would want me too.
Cheers from NH.
New Caretaker of my Grandfathers Model T. Learning how to maintenance it, keep it running and fun drives around the New England Seacoast. Not new to working on cars and motorcycles, but definitely learning the unique things that the Model T has. It is a fun journey and am thankful to have a community like the one here to help. Cheers, Steve
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon Oct 13, 2025 8:24 am
Welcome to the club Steve!
Got my first free start on Saturday. I leave it parked in high gear and glad I put it in neutral first, before switching to Battery.
In process of replacing gasket on sediment bowl.
Opened it up on an empty highway but don't know if it made 40 or not.
Vern (Vieux Carre)
Last Name: Humble
Post by Humblej » Mon Oct 13, 2025 11:02 am
Installed the rear bumpers on my 26 coupe. The Ford bumpers are a real quality product, the bumper bracket holes lined right up with the preexisting holes in the frame. I thought the bumpers sticking so far out would block access to the trunk but there is plenty of room to stand between the bumpers and the body. It is a well thought out design. If I ever do it again though I will be sure to clean the soot off the right rear axle first.
tmagill
Last Name: Magill
Post by tmagill » Mon Oct 13, 2025 2:50 pm
Humbled, l love that color green on your coupe. If you don’t mind could you tell me what color or formula it is in case l ever get around to painting my 26 coupe. Thanks Tim
tmagill
Last Name: Magill
Post by tmagill » Mon Oct 13, 2025 2:51 pm
Humblej stupid spellcheck.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Mon Oct 13, 2025 4:58 pm
Finally starting the restoration of the “aftermarket” brake system on my ‘27 runabout.
the front brakes aren’t very visible.
“early” metropolitan nash backing plate welded to the spindle.
matching 8” metropolitan nash drum welded to the wire wheel T hub.
new brake shoes and wheel cylinders.
wheel back on with new steel jumper line connecting the wheel cylinders.
more pics to come as I work my way back through the system to the 11” GM rear brakes (early ‘60s).
Keep crankin’
Eric
Last Name: Humble
Post by Humblej » Tue Oct 14, 2025 11:57 am
Tim,
I painted my coupe Kewanee Green IM-519. It is a Model A Ford color. It is what Les Henry listed as the correct color in the 1965 "Model T Ford Restoration Handbook" for "Channel Green".
tmagill
Last Name: Magill
Post by tmagill » Tue Oct 14, 2025 4:52 pm
Thanks Jeff, what l can see of your car is beautiful. Tim
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Tue Oct 14, 2025 10:39 pm
Installed battery cut off switch, installed solenoid on starter circuit,and reworked starter cables and installed dual ground cables.
Starter still turns slow so next starter comes off. With the floorboards out the bbendix will be a lot easier to get at. Next I will take it apart and check it over and look for one of the starters I have stored and have not seen in several years. It is always so handy to have parts stored here,there and everywhere but at least I Have some parts.
Post by Mark Gregush » Fri Oct 17, 2025 12:06 am
Put antifreeze in the T and ran it for the first time in about 2 months. Big house project going on so it's on the back burner for a while. Had put the VW carb back on along with the Boach distributor, rev'ing it actually rocked the car! :) The radiator I found on eBay with the newer core, no drips that I can see! Don't have any current photos but this will do for now.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sun Oct 19, 2025 2:19 am
Bit the bullet and converted the Roadster to 12V:
step 1- Replaced the bulbs with 12V
step 2- Installed modified starter for 12V
step 3- Made my own diode cutout *yes very basic diode only to mimic the original cutout.
step 4- swapped in a 12V battery
Done.
Starter cranks with much more energy and coils buzz brightly!
That was easy!
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Post by TheSaintDiscJockey » Sun Oct 19, 2025 4:37 am
Nothing exciting. Installed a new ignition switch plate, new related wiring and picked up a rebuilt generator (need to install). Even got the ammeter working!
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post by CatGuy » Sun Oct 19, 2025 9:48 pm
This past week I was able to get the proper battery cables and new battery installed. This afternoon I tried starting it, but now the starter is acting up. I was able to crank start it and let it run some. Might be driving it soon! It’s been over two years since it was running.
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Mon Oct 20, 2025 10:30 pm
Replaced the New Day timer brush and cleaned the contacts in the cap to solve intermittent mild rough running. Both the cap and old brush have nearly 6000 miles since new.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Post by TXGOAT2 » Tue Oct 21, 2025 12:09 pm
Don't run it on 2 year old gasoline!
CatGuy
Last Name: Hunt
Post by CatGuy » Tue Oct 21, 2025 12:33 pm
I didn't. I drained the tank and added a gallon of new gas just to try things out.
Post by TXGOAT2 » Tue Oct 21, 2025 8:10 pm
One gallon added to a dry tank may not give a very reliable fuel feed, especially with an under seat tank. I'd put in 3 gallons or so to assure fuel flow and to dilute any residual gum that may be in the fuel system. Gas here is available at $2.47 a gallon at WalMart. That's dirt cheap in 1970 dollars!
