1908 2 lever T at auction
KimDobbins
Topic author - Posts: 1631
- First Name: Kim
- Last Name: Dobbins
Lot number F265, Friday oct 31 at mecum auction in Dallas. I have no connection to this car, just supplying the info.
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Re: 1908 2 lever T at auction
Dallas/Ft. Worth. 10/31. A very nice looking car. I'll leave it to the more knowledgeable guys to pick it apart.
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
big2bird
- First Name: Jeffrey
- Last Name: Hausey
I love the yellow wire nut in the engine bay.
Charlie B in N.J.
- Last Name: BRANCA
If only the right side of the block could talk! Not much in the description esp. provenance and really short on pictures......
Is this the same car;
https://www.goodingco.com/lot/1909-mode ... uring-car/
https://rmsothebys.com/auctions/aw07/lo ... t-touring/
Mark Gregush wrote: ↑Mon Oct 20, 2025 12:24 pmIf only the right side of the block could talk! Not much in the description esp. provenance and really short on pictures......
[/quote
https://www.mecum.com/lots/1155382/1908 ... t-touring/
Another question: Are the photo's in the MECUM auction of the same car being auctioned. Parts are disappearing
Carbide tank & running board mismatch
Not the same Sothebys car. Mainly the TOP
Rod
- First Name: Rod
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
- Board Member Since: 2014
Kim,
What do you know about this car? Is it an original number 22? I know you are the guru of two lever T’s.
Thanks,
Rod
Thanks,
Rod
KimDobbins
- First Name: Kim
I've heard a number of stories over the years, best to contact the owner, Aardeen Vaughn in Alvarado, TX. Vaughn specialty Auto.
Frank I see what you mean about the top, the irons are missing from the one car.
Story heard, if true, this horse carriage child hearse, sold, and # 22 motor was found mounted in the early T chassis the hearse was fitted.
Here is that # 22 at Chickasha , 2012, on a run-in stand, was fired up a few times. Pretty neat!
- First Name: Henry
- Last Name: Lee
Hats off to Kim, Frank, and Others on your homework!
Rod
- First Name: Rod
I spoke to Arrdeen and he confirmed that it was originally a Child’s Hearse.
He has owned it for several years.
Here are some pictures he texted to me. They are cleaning it up before the auction.
Michael Paul
- First Name: Michael
- Last Name: Paul
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring, 1909 touring
Is the touring body a reproduction? Does he still have the original hearse body it came with?
Very nice early engine!
How many two lever Fords still exist?
