Timer grease
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Timer grease
Post by Will » Fri Oct 24, 2025 11:25 am
I use the grease on my Anderson timer that Langs sells. Just a light coat works good. I clean and replace the grease before every trip as part of my pre trip maintenance. Iv been using it for years. I'm still using the same timer for the last 15 years and it shows very little wear. My question is now that I'm running low on it just what kind of grease is it?
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Re: Timer grease
Post by Scott_Conger » Fri Oct 24, 2025 11:32 am
You've recently mentioned the car only has 600-700 miles on it in all those years. If you're cleaning and greasing for every trip, that's a personal choice and not a necessity. At 700 miles, the timer wouldn't show much wear if it was simply greased and then never serviced again in that number of miles, anyway...700 miles normally would require 2 cleaning/lube cycles at the most, but if you enjoy doing the work, there's no harm in it and that's the point of the hobby.
If you've been using Lang's supplied grease and feel that the results of extraordinary amount of servicing is worth it, why change?
https://www.modeltford.com/item/3221LUB ... MELWqddXQl
the product is clearly labeled with the manufacturer identified and is commercially available - don't count on it being cheap, as a mere 4oz direct from the manufacturer can run around $15.
give Lang's your business - their $1.75 packet should last several thousand miles.
First Name: Keith
Last Name: Townsend
Re: Timer grease
Post by KWTownsend » Sat Oct 25, 2025 12:53 pm
I check the grease on my Anderson timer maybe once a year or so. I just use wheel bearing grease.
NoelChico
First Name: Noel
Last Name: Chicoine
Re: Timer grease
Post by NoelChico » Sat Oct 25, 2025 11:06 pm
I use Allstar performance extreme pressure lube about $18 on amazon. 4 ounces will last several lifetimes. give some to friends. :D
