Bob Bergstat
WorldChamp1914
Topic author - Posts: 364
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Bob Bergstat
Hi everyone, Is he still on the forum?…….I am missing the ultra thin hexnut on my steering wheel tilt accessory….Thanks
- Last Name: Hjortnaes
Re: Bob Bergstat
I think he is still here, but he sold everything.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Thanks, I found him on EBay….Thanks
Re: Bob Bergstat
I'm in need of the lock nut also.WorldChamp1914 wrote: ↑Tue Oct 28, 2025 7:34 pmHi everyone, Is he still on the forum?…….I am missing the ultra thin hexnut on my steering wheel tilt accessory….Thanks
The nut needed is a lock nut & is the same thread for all of the steering wheel nuts 5/8" x 16 thread (not a standard size). It may be the same size as the Drive Shaft Castle nut. I'm going to check that out. If not grind down a steering wheel nut
Re: Bob Bergstat
Do you have a link to the nut on eBay? I need one also
- First Name: Austin
- Last Name: Farmer
Re: Bob Bergstat
For what it's worth, he is Modelt2001 on ebay.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
5/8 -18 doesn’t work…..I bought some on EBay……the 16 isn’t available there
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Search is hex panel nut
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Now that I know the correct name….I still can’t find 5/8-16….panel hex nut….Grainger doesn’t have any.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Bob Bergstat
Have you tried McMaster-Carr Industrial supply in Atlanta? Opps. Just looked. They don't have them, either.WorldChamp1914 wrote: ↑Wed Oct 29, 2025 2:50 amNow that I know the correct name….I still can’t find 5/8-16….panel hex nut….Grainger doesn’t have any.
- Last Name: Hatch
Re: Bob Bergstat
Maybe this helps
https://www.partswarehouse.com/Homelite ... 011710.htm
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Thank you.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
Thanks for the link, but it is 1/2 inch thick……I did hear back from Bob on EBAY….everything was sold to BirdHaven
Re: Bob Bergstat
That's a very odd thread. You are lucky to find anything usable even with modification needed.WorldChamp1914 wrote: ↑Wed Oct 29, 2025 4:24 pmThanks for the link, but it is 1/2 inch thick……I did hear back from Bob on EBAY….everything was sold to BirdHaven
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: Bob Bergstat
I just talked to Steve Lang, he recommended cutting down a steering wheel nut because it’s 5/8 -16….so I ordered a steel one
