If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Marshall V. Daut
- First Name: Marshall
- Last Name: Daut
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Post
by Marshall V. Daut » Tue Nov 18, 2025 3:46 pm
How in the Sam Hill are you supposed to separate new "best" rod shim packs between layers? 20-30 years ago I used to be able to do it easily with a box cutter blade or even a pen knife blade. But these newer shims must be held together with a space age adhesive that would hold a rocket ship glued together sent to the sun! I have tried various blades and a Bic lighter flame, but still I cannot even get an edge to begin peeling. I'd hate to use an acetylene torch because last time I tried that, I ended up with crispy critters all curled up and useless. Oddly enough, I had no problem peeling shim layers from a new main bearing stack ordered at the same time from the same source.
What's the secret no one is letting me in on???
Marshall
Post
by Jerry VanOoteghem » Tue Nov 18, 2025 5:01 pm
Suspend them from a tag wire and hold over a candle flame. It burns away the parafin(?) that binds them together. Heat gun might work too...
- First Name: Austin
- Last Name: Farmer
Post
by 1925 Touring » Tue Nov 18, 2025 9:56 pm
A trick I picked up a few days ago was to heat them on a burner until the light smoke stops (the 'glue' burning off) in the shim and then set them in water and they should fall apart. I haven't personally tried this yet, but I'm sure it would work.
Marshall V. Daut
- Last Name: Daut
Post
by Marshall V. Daut » Wed Nov 19, 2025 10:45 am
Well, I relented and used an acetylene torch flame to melt the adhesive between the shim layers. Judiciously passing the flame across a shim pack held in a vise from a distance of about three inches, a couple of layers quickly peeled away from each other on the ends without damage. The remaining pack could be easily separated with my fingernails. Problem solved!
Thanks for the input and alternate suggestions for accomplishing this, but I believe a torch is the only way to separate these Iron Maiden shim packs.
Marshall
Post
by TXGOAT2 » Wed Nov 19, 2025 10:57 am
I'd try a solvent, like B-12 Chemtool or lacquer thinner.
- Last Name: Tannehill
Post
by JTT3 » Wed Nov 19, 2025 5:52 pm
You know a cigarette lighter’s flame on the edge of the stack is not as spectacular as a torch but works.
