Info on.... Where to buy 1/0 battery cable- not 2/0
Bill Robinson
Topic author - Posts: 318
- First Name: Bill
- Last Name: Robinson
This post has been deleted.
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Re: Info on.... Where to buy 1/0 battery cable- not 2/0
Bill, Google Battery Cable Replacement. I found several companies making custom battery cables. You have choices of cable size, color, battery terminals, and component terminals both flat and bent to 90 degrees, and MOST important: LENGTH.
Good Luck
Good Luck
Dodge
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
I buy mine at the local welding shop and make up my own ends.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Battery Cables.com
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
The website wouldn’t load
KimDobbins
- First Name: Kim
- Last Name: Dobbins
Batterycablesusa.com
- First Name: Austin
- Last Name: Farmer
Dan McEachern
- First Name: DAN
Thanks Kim! sorry all.........
Y&Z's Yesterdays Parts in Redlands,California. He makes all of my wiring, as I've been unhappy with the vendors offerings! He even figured out how to weave the Ford tags into the loom!
J1MGolden
- Last Name: Golden
Mr. Original, 1/0 is correct for the Electric 1919 to 1927 Model T.
2/0 was correct for the very early Model As, but they soon went back to the 1/0 cables.
I have always wondered, if when they doubled the engine horsepower, they thought they had to double the battery cable size to have an efficient starter.
