Magneto
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
Board Member Since: 2012
Magneto
Post by Oldrusty26 » Fri Jan 09, 2026 11:02 am
Another question for the team, when recharging the magnets on a magneto in the car, do you have to touch each magnet individually or just at the mag post? i’m working on a 1925. I have the hogs head off to inspect the coil rings. Everything looks good but the mags are weak. I was planning on doing the flash charge with a DC welder.
Thank you
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Magneto
Post by Rich P. Bingham » Fri Jan 09, 2026 12:52 pm
Search this forum for the proper procedure for re-charging magnets in an assembled engine. It’s done through the block-mounted coil ring, the transmission cover needs to be on so a compass can be used to properly orient the flywheel. Many say the engine should be aligned with magnetic north, there will be advice on how to use a welder as a power source.
Good luck, and be careful ! (enjoy your T ! :D )
Get a horse !
Re: Magneto
Post by John kuehn » Fri Jan 09, 2026 1:04 pm
Here’s a good forum post about charging the Magneto in the car. http://www.mtfca.com/discus/messages/506218/528397.html
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 12:39 pm
Thanks , hopefully it will be done today!!
Re: Magneto
Post by speedytinc » Sat Jan 10, 2026 1:01 pm
The compass method assures that (A) a coil is centered over the magnet ends & (B) correct polarity.
Physically looking @ the position of the magnet keeper screws thru the inspection cover will, even more accurately cover (A).
Polarity is not important with a saturation re-charge. However if you dont believe the exhaustive testing Tom C. did in this regard, use you compass to confirm polarity after sighting the magnet keeper screws. Have the car pointing in an East/West direction.
Definitely read Tom C's posts. His method is proven, works great.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 7:59 pm
I set the chassis east and west , used a compass to determine north and south . Ended up using the 3 battery set up to flash with the positive on the solder button and striking ground to the engine block , it worked somewhat , but the magnets aren’t as strong as I feel they should be , but they’re stronger than they were if that makes sense .
Re: Magneto
Post by speedytinc » Sat Jan 10, 2026 8:35 pm
Did you line up the magnet screws as I suggested? 3 batteries isnt enough for a saturation charge. A high output dc power source from a welder works best In my experience.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 9:26 pm
I’m going to try the welder tomorrow, I’ll post my results . Thanks !!
Re: Magneto
Post by Scott_Conger » Sat Jan 10, 2026 10:08 pm
When you're done with the magnets, don't ignore the bands and band material which all look to need attention, as well as possible two-piece valves.
Be careful about stacking loose things around that abyss - it's no fun fishing parts out and even less fun starting the car up and finding out you should have spent more time fishing.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 10:36 pm
Very good advice !! I will definitely clean up the area before moving forward , I pulled this unit out of a barn quite a few years ago and am looking forward to getting it back together . They are the two piece valves , the whole thing needs cleaned up and out .
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Tue Jan 13, 2026 6:37 pm
Tried the welder method @225 dc , flashed ground , no change , magnets will let the compass read north and south , but that’s all the magnetism I get ….
Re: Magneto
Post by speedytinc » Tue Jan 13, 2026 6:43 pm
What are you using to determine how strong the magnets are before & after a recharge?
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Tue Jan 13, 2026 8:16 pm
A socket to see if it sticks to the magnets , it does not . Magnets are very weak . Would rather not pull the flywheel and transmission assembly but I may have to.
jab35
Last Name: Bartsch
Re: Magneto
Post by jab35 » Wed Jan 14, 2026 11:47 am
Puzzling result for sure. Any chance mag stator coil ring is open/shorted? And have you minimized magnet to stator gap by pushing flywheel fully to front of engine? 36VDC from batteries should do that when you 'flash charge' the magneto. Seems likely to me there's a faut somewhere in the mag ring coils. Good luck, jb
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Wed Jan 14, 2026 12:44 pm
I will try that next and report back. For checking the coil ring , just make sure there’s continuity between the coils and no short to ground correct ?
Re: Magneto
Post by TXGOAT2 » Wed Jan 14, 2026 1:04 pm
A socket may not give an accurate idea of magnet strength. Good sockets are hard forged chrome or vanadium alloy steel, which may not stick to a magnet as well as mild steel. Try using a piece of mild steel to test the magnets. The best test of a magneto is to start the engine and measure the output voltage with an AC voltmeter. The voltages that should be present at various speeds vary from 6 to 8 volts at slow idle to 30 volts or more at 1800 RPM.
Re: Magneto
Post by speedytinc » Wed Jan 14, 2026 1:31 pm
I wonder if you could do a light bulbs test. See if you can light a 6v bulb with a vigorous spin of the crank.
That would test actual output.
Last Name: Hatch
Re: Magneto
Post by Dan Hatch » Wed Jan 14, 2026 2:22 pm
Ok one more time.
Take a fish scale ( not the ones you remove from fish before cooking).
Bend a short piece of steel flat bar ( 1/2”wide x long enough to fit cross magnet ends)
Drill hole in middle, attach small eyebolt.
Place on end of magnet, hook scale to it and pull.
When bar pulls off magnet, record lbs of pull need.
That gives you good idea of magnet strength. Dan
Re: Magneto
Post by speedytinc » Wed Jan 14, 2026 2:34 pm
Ok one more time.
What's a good # to see when testing the pull on an assembled flywheel?
I have charged loose magnets to a 4# pull. After installing into a complete flywheel Magnetism was noticeably less.
My imagination or is there a scientific explanation?
Magneto puts out 33 VAC measured.(that's what magnet saturation will give you)
Re: Magneto
Post by TXGOAT2 » Wed Jan 14, 2026 3:28 pm
Magnets mounted in place on the flywheel will probably behave differently than loose magnets. Most alloy steels, such as sockets and other tools, contain non-ferrous metals and are less attracted to magnets than mild steel or soft iron. You need to connect an AC voltmeter to the mag post and crank the engine with the plugs out and ignition off. A meter with a 0 to 50 AC volt scale should work. Don't start the engine with the hogshead off or the access cover off the hogshead. Oil will go everywhere if you do. Spinning the engine with the hand crank ought to show 8 to 10 volts on an AC meter connected to the mag post and to a good ground.
Mike Silbert
Last Name: Silbert
Re: Magneto
Post by Mike Silbert » Wed Jan 14, 2026 5:25 pm
Even if you hand crank the engine quickly enough to get a magneto reading it will be dumping the oil.
If you do the hand crank magneto test with the hoggs head removed, drain out the oil.
And DO NOT start it without it being fully assembled, sealed and full of oil.
I have dumped lots of oil on the garage floor thinking it can't leak that much.....
Mike
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Wed Jan 14, 2026 5:59 pm
Ok , so , checked coil ring continuity , not open , however checked the solder blob ( hogshead is off ) and have continuity to ground , ensured that the flywheel magnets were as close as they could be to the coils , flashed again , nothing , compass reads north and south poles and with a small piece of steel strap , very little magnetic pull , as in practically none , not even enough to read on the pull gauge . So am I right to believe this one needs to have the magnets either replaced or sent out for recharging ?
Re: Magneto
Post by TXGOAT2 » Wed Jan 14, 2026 6:18 pm
If you mean the steel strapping as used on boxes and crates, it may not be ideal, either. What you need is mild, soft steel. I don't think you can get a meaningful magnet test with the magnets assembled to the fly wheel except by rotating the flywheel and checking voltage. I'd drain the oil as suggested above and get hold of an analog AC voltmeter with a 0-50 range. You can buy an inexpensive multi-meter at Wal Mart or most any auto parts store that will do the job. They are handy to have on hand for general use.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Wed Jan 14, 2026 6:32 pm
Strap was cold roll steel about 1/8” thick and 4” long , not sticking anywhere , but has some draw to the magnets , hand cranking ( hogshead is off and oil drained ) 0.7 vac on a fluke multi meter ( not analog )
Re: Magneto
Post by speedytinc » Wed Jan 14, 2026 6:47 pm
NO.
You don't know that the field coil is not grounded @ the first coil from a continuity test.
If the coil was out, you could put power to it & check each coil for alternating magnetism.
When you flashed the coil, you should have heard/felt a healthy thump from the coil pulling in the flywheel.
Are you sure your welder is DC?
Magnets, generally don't go "bad", they need replacing if cracked.
A saturation charge in car is not any better than a saturation charge done individually.
In fact, in reassembling individual magnets, they can lose some charge from hitting to reset magnet heights.
.7 is no good. You don't need to use an analog meter if buzzing coils are not involved.
So your description says the magnets are not adequately charged. I think that can be concluded, but not necessarily the fitness of your field coil.
Mike Silbert
Last Name: Silbert
Re: Magneto
Post by Mike Silbert » Wed Jan 14, 2026 7:24 pm
To check for magneto ring coil shorts or opens:
1) Line up the magnets to the coils like you are charging it. Skip this if it is a loose ring coil bench test.
2) Hook up a 6V battery or 6V charger to the ring coil like you are charging the magnets. Don't leave it hooked up long as it will heat up parts.
3) Go around the the coils and see if a big wrench "sticks" to the coils.
Most importantly check the last one in line that is on the generator side of the engine next to the post.
I have seen ground shorts between and in the coils (taking some of the coils out), bad connections, bad ground rivets, and windings shorted between the layers before.
If you suspect there is a problem with the ring coil it is an easy test.
Mike
Re: Magneto
Post by Scott_Conger » Wed Jan 14, 2026 7:41 pm
Fluke DVM will all but certainly give erroneous readings regardless of health of the mag coil, and without a small load such as a light bulb during cranking, you will not get a real meaningful reading with an analogue meter, either. A St. Louis Magneto tester is best, but this test in this link is darn near equivalent and a whole lot cheaper: https://www.mtfca.com/discus/messages/7 ... 760271.pdf
You need help - the kind that means someone is standing next to you that has experience trouble shooting this sort of thing. I am with others who suspect your coil ring, but on the other hand, don't believe that your test methods are adequate, either. You may have a shorted mag ring, or quite possibly simply have a worn out 3rd main bearing allowing the magnets to sit too far away from the coils to properly charge (or subsequently provide adequate voltage to work the coils). Dealing with well-meaning respondents is no substitute for thorough checking with adequate methods and equipment along with immediate advice from someone working with you who has experience with this sort of thing.
Unfortunately, you are delving into one of the more potentially confounding issues that a T can have, thus my admonition to do your very best to enlist experienced help.
If I were you, I'd start a thread asking for local help with Magneto Troubles
good luck
Last Name: Hatch
Re: Magneto
Post by Dan Hatch » Thu Jan 15, 2026 5:30 am
There is a back issue of VF that has a good description on doing a in car charging.
Measure the resistance of mag coil. Should read around.5ohm to ground.
I think you just didn’t have the magnets lined up correctly.
There is also an article in one of the Tinkering Tips books about how to do a recharge. Dan
Re: Magneto
Post by speedytinc » Thu Jan 15, 2026 8:14 am
Mike
OP shows his engine with the flywheel attached.
How can you test the field coils individual coil strength as you suggest in #3?
What am I missing? If you have a magic answer, I would add this to my diagnostic bag of tricks also.
Last Name: Hatch
Re: Magneto
Post by Dan Hatch » Thu Jan 15, 2026 9:06 am
Here is diagram from “Tinkering Tips”. Show easy way to do it.
Mike Silbert
Last Name: Silbert
Re: Magneto
Post by Mike Silbert » Thu Jan 15, 2026 10:49 am
John and all,
Detecting a partial short dropping the 0.5 ohms to say 0.25 ohms is really difficult for a meter.
Heck just telling the difference between zero and 0.5 ohms is difficult.
The magneto ring coil is essentially about 160 feet of wire wound up in a special way.
The test I described is a modified version of the in car magneto charger.
Most of the time I do this test on a loose magneto ring coil on the bench to verify it works properly before installation.
It is not nearly as nice of a test when done installed.
6 volts is safer, 12 volts will work but limit the time it is on more to avoid overheating.
More voltage is a greater magnetic field so it is easier to detect.
A properly functioning magneto can put out in the neighborhood of 26 volts AC max so if the insulation can't handle lower voltage you need to know.
Same as when you are using the ring coil to charge magnets it needs to be a short time test to avoid overheating.
The car in question has the hoggs head removed in a picture so you can actually get in there.
This test will not work with the hoggs head installed.
He says the magnets are weak and will barely hold anything, this test will not work very well on a fully charged set.
When you pass electric current through the magneto it turns the coils into 16 electromagnets.
This magnetic field can either charge or discharge the magnets on the flywheel depending on how it is aligned.
This is why alignment is so critical so you do not make things worse.
The wiring connections are inside the coils making them impossible to inspect when installed in a car.
But these connections are where I have seen shorts to ground before.
With the pan installed only 8 of the 16 coils can be reached directly so this test is not 100% complete but it will give a good idea of condition.
The only thing it will not detect is a short between the windings but not to ground on the lower 8 of the coils.
Since there was reported conductivity of the assembly it should produce some magnetism somewhere.
Of course if there is no current flow and magnetism then a connection can not tolerate current and is barely hanging on.
We are looking for the magnetism to increase when being charged vs the level when not being charged.
If there is an open or bad connection it will not change the magnetic level or draw current.
If there is a short to ground some coils will make magnetism and some will not.
The last coil in line before the ground rivet is the most important. If there is a short anywhere before it in the loop then it will be dead.
If the last coil is alive then there can not be a short to ground anywhere before it in the loop.
If there is an inner winding short then it will produce less magnetism on that coil. Without a gauss (magnetic field strength) meter this probably is not noticeable.
We are also looking to hear the tink sound of the bottom touching when charging meaning it is actually doing something.
While I feel that likely a mistake was made on the charging attempt, its hard to get it correct even for experienced T mechanics.
I can not rule out the possibility that there is a problem somewhere else.
While the test I describe is not perfect, it is fairly quick and easy.
Ruling out a magneto ring coil problem would be helpful in solving this issue.
I prefer to test parts and know they are good before reassembly rather than trust it and have to go back in again later.
I also like to know exactly what is wrong before digging in to make sure I get it all fixed.
More test and less guess is my style and what works for me.
Everyone has to do things in their style.
Mike
Re: Magneto
Post by TXGOAT2 » Thu Jan 15, 2026 12:24 pm
You can't repair the coil ring in the car, and taking it out is a major operation.
I'd drain the oil, pull the spark plugs, put an AC low-range voltmeter on it, and spin the crank for all I was worth. If the meter shows a few volts, the mag may work. Put the hogshead back on, plugs back in, 10W30 oil in, and start the car on BAT, then see if it will run on MAG. If it does, you're OK. When the engine is warmed up, see if it will start on MAG. If it does, you're in fair to good shape. Then let the car sit overnight and see if you can start it on MAG. If so, you are in very good shape.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 17, 2026 5:56 pm
Ok , did mikes test with 6v charger , all reachable coils are magnetized when hooked to the charger , the first one left of the blob and the right one as well , I think I’m just going to put it all back together and start it up to see if it runs on mag .
Thank you all for your help !! This one’s been a bugger 😜😜
Re: Magneto
Post by speedytinc » Sat Jan 17, 2026 6:45 pm
I would still see I a vigorous crank would light a 6v bulb. If nothing, mag is dead. If It lights, that would indicate enough output to run @ normal running speeds.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 17, 2026 7:45 pm
Will do , just fasten the positive to the blob and the negative to the block ? Do I need to do anything else ? ( other than cranking the engine ) the engine just sitting in the frame and nothing else is hooked up to it .
Re: Magneto
Post by TXGOAT2 » Sat Jan 17, 2026 8:06 pm
+ or - don't matter on AC. Hook one wire to the solder blob and the other to a good ground on the engine. Use a 6 volt bulb, such as a tail light bulb, and be sure the bulb and connections are good. If the bulb glows red, that's weak. A bright orange or yellow glow is better. It probably won't glow brightly, but if it does, good news.
Tom D
First Name: Thomas
Last Name: Draude
* REQUIRED* Type and Year of Model Ts owned: 1925 touring
Re: Magneto
Post by Tom D » Sat Jan 17, 2026 8:58 pm
It seems it would be accurate enough to place 6 volts across the coil assembly, accurately read both voltage and amp draw to accurately calculate the 0.5 (or whatever the specified ohms) of the coil. One would think any shorts significant enough to affect output should be evident.
Tom
Mike Silbert
Last Name: Silbert
Re: Magneto
Post by Mike Silbert » Sun Jan 18, 2026 12:53 am
As long as you were not tricked by magnetism from the magnets nearby, the magneto ring coil has life.
That is good news, its a big job to replace one.
Before reinstalling the hoggs head double check the magneto gap.
And check for crankshaft end play while you are at it.
I doubt they are an issue but are easy to check and verify before you close it back up.
It's good to know these numbers because they do make a difference to how well the magneto works.
While you are in there inspect the magneto post, those short or open sometimes.
They can give you fits sometimes when they act up.
And it should not be installed when the hoggs head goes on to avoid damaging it.
Mike
Mike Silbert
Last Name: Silbert
Re: Magneto
Post by Mike Silbert » Sun Jan 18, 2026 8:59 am
On a bit of an aside:
What welder did you use?
The 225 you quoted is maximum amps.
Welder output voltage is all over the place and varies depending on the make and model of the welder.
I have seen specs anywhere from 10 volts to 40 volts depending on the model.
To get higher current (and increase safety) the voltage is lower on the output than line voltage.
The important specification is running (while arcing) voltage and the open circuit voltage is good to know.
I use charged 12 volt batteries because I know for sure what I am getting in spite of owning multiple electric welders.
Mike
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sun Jan 18, 2026 12:30 pm
Ok , today I am eating an entire humble pie !! I went out to the barn determined to find out what was wrong with my magneto and it turns out that I was the problem , my DC welder is not a DC welder , it’s an AC welder . So … re set up with the three battery set up again and recharged/flashed the Magnets , now I have decent magnetic pull. hooked up a 6v lamp to the blob and turned the engine over by hand , bulb lights up as it should , gets brighter the faster I pull … thanks for everybodies help and suggestions . Guess I need to start by paying more attention to the facts and maybe get my eyes checked , because I was sure that damned “A” was a “D” , thanks again for your time and effort/support.
This pie tastes good though , and I’m sure I’m not the only one who has ever tasted it !! 😜😜😜
Mike Silbert
Last Name: Silbert
Re: Magneto
Post by Mike Silbert » Sun Jan 18, 2026 1:00 pm
I am sure we have all been there before, I know I have.
At least your pie tastes good and it will be back on the road soon!
After many years of field service and lab repair work you learn that sometimes the issue is the thing you believe to be correct.
When things go wrong and don't make sense, step back and go over everything.
I have returned to the beginning and tried to reproduce the problem many times.
Sometimes you fixed the problem and did not know it.
Humble pie, Eating crow, Egg on your face, Can't See the forest for the trees, If it was a snake it would have bit you, or just plain a mistake, it happens sometimes.
Now you have a good story and will never forget this.
Mike
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sun Jan 18, 2026 1:20 pm
1000% correct Mike !! Thank you all again very much 👍🏼👍🏼👍🏼👍🏼
browning
First Name: David
Last Name: Kahle
* REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
Re: Magneto
Post by browning » Sun Jan 18, 2026 1:32 pm
Congratulations Travis, I’m thankful that I am not the only one that sometimes misses the forest for the trees, been there many times. A great asset to do the recharge in the car is an electric golf cart. They are usually 48 volts but can be jumped to provide 8 volt increments which is handy. You can drive them to the site, batteries are designed for heavy load, and are easy to recharge. Visit when you can.
Re: Magneto
Post by TXGOAT2 » Sun Jan 18, 2026 1:40 pm
Golf cart is a good idea. I think batteries would be the best source of a heavy jolt of pure DC current. If you use car batteries in a series hook up, be sure ALL of them are in good condition and fully charged.
Re: Magneto
Post by speedytinc » Sun Jan 18, 2026 2:51 pm
Congratulations.
I figured you were using an ac welder.
The big clue was 225 . Thats the common lincon arc welder.
Been there done that once also.
