Another generator question - A new one on me!
Marshall V. Daut
First Name: Marshall
Last Name: Daut
Post by Marshall V. Daut » Mon Jan 12, 2026 4:28 pm
After finally getting the engine to run in a friend's newly-purchased '26 T, it was noted that the ammeter did not register a charge even when the engine was revved up. The ammeter was wired backwards (of course!), showing a charge when the lights were tested. Once the ammeter wires were corrected, turning on the headlights gave a discharge on the ammeter. So, we know the ammeter works on both sides of zero.
Before polarizing the generator, I thought it best to remove the cutout to see if it could possibly be an electronic model, which is not supposed to be jumpered. Thank goodness I did that - it is an expensive electronic cutout for negative systems. 'Dodged the bullet there! I will assume it's good, as it appears brand-new.
Removing the generator to test it with a battery, it "motored", maybe not as fast as I would like, but it did spin. That's a plus = the armature isn't burned out. The cover band was removed and I was greeted by an additional two-wire affair with a fuse, which I had never seen. The fuse filament does not appear to be broken. Look at the photos. What is this for? I am reluctant to adjust the third brush holder to increase the charging rate because what if this wiring addition is some kind of regulator or surge protector and by me attempting to increase the charging rate, I screw something up? I know I need to clean the armature plates, but if they were really terrible, the generator wouldn't even motor.
Should I loosen the third brush plate via the nut (see arrow) and move the holder to increase the charging rate? If not, why does the generator motor, but not put out a charge?
Marshall[image][/image]
Moxie26
Last Name: Jablonski
Re: Another generator question - A new one on me!
Post by Moxie26 » Mon Jan 12, 2026 5:20 pm
Marshall.. that generator could be a Patterson rebuild, as he did put a fuse in like that. I would suggest getting a flathead wood clothespin, cut a strip of 320 sandpaper and apply that to the clothespin head. Start the car and apply the 320 sandpaper to clean up those contacts. You should get the positive reading on your ammeter. Some people have even used brake cleaner spray with the straw attached to clean contacts in the running mode.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Mon Jan 12, 2026 5:39 pm
The fuse should be between the field wire and the third brush.
Why the fuse:
By a broken connection to the battery, the generator will build up his output well over 20V. ( tried it with a volt meter over a test light between the generator post and its house. At 28V the light burned out)
Also the current in the field will go up. The fuse will burn and the generator will be safe.
Andre
Belgium
Post by speedytinc » Mon Jan 12, 2026 8:58 pm
A generator that wont motor wonr work.
A generator that will motor might work.
I would put back on the motor. Run & clean the commutator with fine sand paper.
Make sure the brushes all move freely & are contacting the commuter.
Take an analog voltage reading @ the output terminal. 0 volts = dead. 7.5V + good.
Start with increasing the 3rd brush.(move toward motor) If you get a good voltage reading or ammeter reading, great.
If not.....
Follow the in car generator adjustment from the service manual.
Still no joy? - rebuild time.
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Mon Jan 12, 2026 9:36 pm
I will follow the suggestions given so far, now that I know the in-line fuse is just a protection against burning up the generator. Thank you, all.
Looking for other possible causes of the charge not reaching the ammeter, I studied the HUGE wiring diagram by Patsy Winn, tracing from the generator to the firewall terminal block and hence to the ammeter. When I swapped wires around on the ammeter to get the correct orientation, I noticed that the short wire on the diagram running from "Batt." on the switch to the "+" side ammeter terminal is missing (see yellow arrow on attachment). Granted, the diagram is for a 1919 to 1925 Model T with starter, but unless this wire was dropped in 1926, shouldn't it be there, connecting the switch to the ammeter? That would make TWO wires on the positive ammeter post, not counting the dash light, which is also missing from this car. I am wondering if perhaps the lack of this wire might explain why the charge from the generator isn't making it to the ammeter. Yet, in the wiring diagram in MTFCA's Electrical Booklet, this short wire is present, but the longer wire from the "Batt." terminal strip does NOT run up to the ammeter, meaning the "+" ammeter terminal has only ONE wire connected to it. Which is correct for my friend's 1926 T and could the missing short connecting wire be why the generator's juice doesn't reach the ammeter? Grasping for straws here... :)
Marshall
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Mon Jan 12, 2026 11:18 pm
Marshall,
For a 1926 wiring diagram I use the ones on the Texas T Parts website
https://www.texastparts.com/mm5/manuals ... iagram.pdf
The wiring to the ammeter can be done in several ways.
Some will work fine and others not so.
And some wiring diagrams and replacement ammeters have the wiring backwards so it needs to be checked carefully.
Sometimes the 2 wires are under the terminal on the switch side and not the ammeter.
While you are in there check that all connections, including the bus bar rivet, are good to prevent future problems.
If the car has a dome light or dash light there will be a 3rd wire somewhere.
The bottom line is that the battery (yellow wire) goes on one side of the ammeter.
The other side gets the generator wire (Yellow w/ black stripe), the Ignition switch wire feed wire (Yellow w/ black stripe), and any dome or dash light wires. Somewhere all these wires get connected together and it can be at the ammeter or the switch terminal marked BAT. The electrons do not care which ends of the jumper wire the generator is hooked to. It belongs on the ammeter stud because that is a taller, stronger connection with more room for stacked connections.
If the ammeter works backwards then all wires on each terminal need to be swapped like you did.
Mike
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Mon Jan 12, 2026 11:32 pm
Mike -
Thanks for the explanations and 1926-27 wiring diagram. This one shows a wire going from the generator screw in the terminal block to the horn button. Doesn't it usually come from the "Batt." screw in the terminal strip? It seems that no two Model T wiring diagrams agree on all points.
O.K. Given that this Texas T Parts diagram also shows that short connecting wire from the switch to the ammeter, what would be the symptoms if that wire were missing, as in my friend's Model T? That wire must be there for some reason! Everything else electrical seems to work = ignition (on battery and on magneto), headlights, and taillight. The only thing left non-functioning is the generator not sending juice to the ammeter. That fact and the missing connecting wire make me think there is a relationship between the two. Is there? What would happen without that short wire connection?
Marshall
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Jan 13, 2026 6:55 am
Deleted...
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Jan 13, 2026 8:22 am
Marshall,
Besides Ford changing the wiring several times over the years as the Model T was "modernized" creating multiple different wiring diagrams there is more confusion.
Wiring diagrams have been made over the years with varying degrees of accuracy.
Then on top of that wiring harnesses have been made, customized and repaired in various configurations some not stock.
Cloth wiring gets dirty easily and quickly turning all wires black making color codes useless.
Add on top of that harnesses have been installed in different ways by owners over the years and you have a mess.
Do the best you can to follow the wiring diagram but remember it might not be 100% accurate to your situation.
Follow what the car and parts tell you needs to be done.
Double check and test things before calling it good.
I wish things were more clear but it is what we have today.
I am thankful they are as good as we have it after more than 100 years.
Mike
Ron Patterson
First Name: Ronald
Last Name: Patterson
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout
Post by Ron Patterson » Tue Jan 13, 2026 9:26 am
Marahall
If I can help if you give me a call. I think I know what is wrong with the generator.
Trouble shooting the Model T charging/discharging/wiring issues is easy.
First you need a CORRRECT wiring diagram. Many wiring diagrams being passed around on this forum (including the one shown above and referred to above) are incorrect in several ways. There is a reason the wire from the generator to the switch and jumper to the ammeter is wired the way shown in my diagram, Those pesky 5 wires in the charge/discharge circuits ars shown in the attached diagram for a reason. Verifying this requires a few easy steps.
I realized the incorrect wiring diagram issue issue years ago and made an absolutely correct 1922-1927 wiring diagram (attached). I refuse to use any other wiring diagram when helping other with wiring issues and do nt believe what the owner tell you......Verify first. Nothing is more frustrating that asking the owner and then find out he actually did not know.
Second you need the document I wrote years ago (attached). It is a simple step by step procedure for trouble shooting, understanding how the third-brush regulation generator actually works and how you can verify if it is working correctly.
As stated above the fuse is commonly found added to prevent the generator from destroying itself when the battery is disconnected from the generator and running the engine.
Hope this helps
Ron Patterson
P.S. I did not rebuild the generator above. I only added a fuse if the owner asked me too and then it was done using good workmanship, not that mess. Never take electrical advice from an undertaker :)
Trouble Shooting the Model T Ford Charging System-6-14-2022.pdf
(603.14 KiB) Downloaded 47 times
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Tue Jan 13, 2026 9:27 am
here is the second attachment.
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Tue Jan 13, 2026 9:28 am
Try agian.
Trouble Shooting the Model T Ford Charging System-6-14-2022.docx
(1.3 MiB) Downloaded 54 times
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Tue Jan 13, 2026 9:34 am
Sorry
You can download the PDF
Ron
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Tue Jan 13, 2026 9:43 am
Here is another article which simply explains how the Model T charging system works.
The Model T Ford Battery Charging System.pdf
(322.23 KiB) Downloaded 66 times
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Tue Jan 13, 2026 9:44 am
Wow, Ron! Impressive! I was hoping you'd jump in here with your always useful advice - and you did! I really appreciate all that you wrote and the diagrams/troubleshooting guides you posted. I will read through and study them today and try the simple things first tomorrow when I can return to the generator. Should those not rectify the problem, I will call you. From our past conversations, you know what a dunce I am when it comes to electrical issues. Those problems have been my bug-a-boo in antique cars since I first got into the hobby. My mind simply does not think in terms of electrons and Ohms. And it seems that most Model A's and T's I work on for friends have starter and generator problems inherited from previous owners who skirted by the problems and just left them for me to fix. With Model T's I'd say it's a 50-50 mix between starter and generator woes, probably 20-80 respectively in Model A's. You'd think by now I'd be an expert in all things automotive electric. Nope! What you and others have posted so far ought to help even me correct the problem. But I will turn to you as a last resort if all else fails. That the armature spins when powered gives me great hope that the cause of the non-charging is something simple I have overlooked, possibly as simple as the armature plates being too filthy. Basics first, send in the Marines second.
Thanks again for sharing your expertise with us all. I'm sure I can't be the only electrically-challenged reader here! The information posted by all so far should help those owners out there who are as equally inept electrically as I am. :)
Marshall
Post by Scott_Conger » Tue Jan 13, 2026 9:53 am
Accurate wiring diagram, color coded wiring on back of the switch - https://www.mtfca.com/discus/messages/8 ... 1532718210 or a link to Ron's diagram that is a bit larger and easier to see - https://www.mtfca.com/discus/messages/7 ... 1496841727
A generator that motors "slowly" and has a black commutator has problems. Cleaning up the commutator with 320 grit and leaving that finish on it without dressing it with finer and finer grades of paper (to at least 600 or better still, 800-1000) will now have a new problem - a very rough commutator...it might make the generator work for awhile, but proper attention paid to the commutator during remanufacturing (or general putzing around) will be the difference between a very long-lived generator and one that gives up soon after (and add to the "damn generators are no good" myth).
Ensure that the wiring conforms to Ron Patterson's drawing in the link I provided, and ensuring the switch/ammeter is wired as illustrated by Dan Treace in that same (first) link, and finally, let someone who has a proper test set and knows generators look at the generator. Right now, you have questionable wiring and are assuming the generator works - Under those two conditions, you're not on very solid ground to move forward with this problem. Doing these two things will stop all of the tail-chasing. If the generator can be made to function, do not be surprised if the advice is to simply overhaul it anyway. Once a generator looks as this one does, there are any number of marginal issues just waiting to crop up and cause further headaches. A correctly overhauled generator will be capable of running for many thousands of miles over decades of service before needing attention again so long as it is not abused.
Finally, if the generator does finally "wake up" and things are not right on the wiring diagram, you will be very happy to have had that fuse in the generator...check it frequently, as it may eventually be the savior if the armature but the cause of frustration (if you don't know it blew).
Be careful and good luck
WOW - after walking away and coming back to hit "submit", a lot of stuff has occurred! Work with Ron
AndreFordT
First Name: Andre
Post by AndreFordT » Wed Jan 14, 2026 2:28 am
Thank you Ron.
Andre
Belgium
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Wed Jan 14, 2026 5:14 pm
Well, another frustrating day in the books. This generator continues to torture me. I sanded the commutator plates with 320, followed by 600 and then 1000. They cleaned up nicely. Before doing that, I tested how fast the armature turned over with a battery. It motored o.k. After cleaning the commutator, the armature turned faster. Moving the 3rd brush resulted in the slower and faster spinning speeds one would expect at the extremes. But - once reinstalled to the engine, there still is no charge registering at the ammeter. I tried a second cutout of unknown quality with the same no-charge result. The headlights do not get brighter when the engine is revved up from idle.
The wiring from the terminal block to the switch and hence to the ammeter is the way Ron's diagram shows it for the '26-27 Model T's. So, I think we can rule out wiring as the culprit. I have found that in other generators I have worked on - mostly Model A - if the armature spun at the speed I am seeing here, the generator would send out a charge. I realize a generator will never motor as fast as a starter, which jumps when a battery is hooked up to it. All these signs tell me the generator is good. So, why no charge?
I will try a known good cutout that I have to remove from a friend's engine tomorrow. But, isn't there a simple way to test if the generator has output while the engine is running, such as running a wire from the terminal post to the engine block? If it sparks, wouldn't that mean the generator is working? With the electronic cutout now in place, should I remove that first so that I don't burn it up?
Marshall
Post by speedytinc » Wed Jan 14, 2026 5:24 pm
I already told you a simple in car test plus a total reset in case the null point is way off.
Post by speedytinc » Mon Jan 12, 2026 6:58 pm
A generator that wont motor wont work.
If not.....
Follow the in car generator adjustment from the SERVICE MANUAL
The above checks the generator, excluding bad wiring.
Do you have battery power to the cutout?
& yes, I would put a non VR on just to be safe for not accidentally burning it out. You can also safely polarize the generator in case that's needed.
You have a service manual don't you?
Post by speedytinc » Wed Jan 14, 2026 5:35 pm
IF the battery was hooked up wrong.(positive ground)
Hence the reason the ammeter was backwards, a simple re-polarization could be all it needs.
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Wed Jan 14, 2026 5:57 pm
About time you called me.
Ron Patterson
Post by speedytinc » Wed Jan 14, 2026 6:14 pm
Ron Patterson
I second that.
Ron knows his stuff, call him.
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Fri Jan 16, 2026 11:07 am
Update: I tried all suggestions posted, except using a voltmeter to test the generator's output because I don't have one. 'Doesn't matter, though, because even though I also did everything the Model service manual and the MTFCA manual said to do, the generator still doesn't work. I temporarily installed a known good generator with my friend's electronic cutout and the ammeter showed a charge. So, the problem is definitely in the generator itself, not with the cutout or wiring.
I disassembled the darned thing yesterday and had a heck of a time reaching the screw on the third brush, no matter how far it was slid on the brush plate. The case was in the way at each position. Aha! This can't be right! I also had a heck of time trying to move the third brush, loosening the nut to the point that it almost dropped off the stud before I could budge it. Another red flag! I removed the four screws on the end cover in order to reach the third brush screw brush screw. I suspected the plate had been installed incorrectly. Someone had been inside this generator, as the brush plate insulators had been replaced - the lazy way by simply cutting off most of the insulators and only installing a portion of the new ones. Photos supplied by Ron Patterson proved that the brush plate had been incorrectly oriented.
Ron spent a great deal of time with me this morning patiently explaining what he thought was the problem. His explanations and instructions were most welcome and informative. Thank you again, Ron! As a starting point, I will buy a correct brush plate rather than screwing up this one by trying to install new insulators. I think this was the major problem why the generator doesn't work: the way the insulators had been sandwiched together and the incorrect positioning of the brush plate. If this doesn't solve the problem, it's on to more drastic measures. I'll re-post once the new brush plate has arrived and the generator is back on the car. After talking with Ron, I feel confident that the darned thing will work. If not, Ron recommends buying an exchange unit. That's probably the best solution, but I want to try and save this poor little critter first.
Marshall
Last edited by Marshall V. Daut on Fri Jan 16, 2026 1:49 pm, edited 1 time in total.
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Fri Jan 16, 2026 1:48 pm
It must be fate! Right after posting the above message, my wife and I went out for a Chinese lunch. In my fortune cookie was this message, which re-inforces my determination to see this generator repair through to the bitter end! :)
Marshall
jab35
Last Name: Bartsch
Post by jab35 » Fri Jan 16, 2026 3:04 pm
Marshall: Connecting with Ron P is always helpful for electrical systems advice. He has helped me tremendously over the years and I'm grateful for his assistance and advice.
I encourage you to pursue brush plate insulator replacement if you are game, your fortune says you are! I did this successfully a few years ago with Ron's guidance along with the info in this excellent video > https://www.youtube.com/watch?v=C7Psk4hK3gU The brushplate insulator replacement procedure begins right after time 14:00. As Stelf Jelf says, "It ain't rocket surgery".
Before starting, get an inexpensive analog volt/ohm meter and check the resistance between the insulated brush holder and the plate it's mounted to. That value should be essentially Infinite Ohms, indicating the insulator is still electrically functional. If that insulated brush holder is grounded to the plate, the insulator is bad and removing it, replacing the two insulation sheets and reattaching the insulated brush holder is more involved, but definitely doable. The video does not show removal/reattachment of the insulated brush holder, they leave that in place and trim the new insulator sheets accordingly. Recheck resistance after you complete the work and install the 3rd brush holder making sure insulated parts are insulated. Then install brush plate in the generator and follow Ron P's guidline for setting endplate null position and position of 3rd brush holder.
You can't make anything worse and if it doesn't fix things you still have a core to exchange.
I recommend using the fiberglass 'best quality' insulators, two are needed one has to be slightly shaped to fit abound the ridge in the brush plate, the video shows it all. Some use pop rivets instead of the tube rivets shown in the video.
All the best, jb
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Sat Jan 17, 2026 8:19 am
Yup! How can anyone argue with a fortune cookie's advice? After all, it was a fortune cookie that led Aunt Bea to invest in a Chinese restaurant in Mayberry, wasn't it? If I had been teetering on the fence beforehand whether to attempt a repair of this generator or simply exchange it, the fortune cookie made up my mind: full speed ahead with a repair attempt! Whoever heard of a fortune cookie's prediction being wrong??? "Darn clever, those Chinese!", quoteth Howard Sprague.
M.
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Wed Mar 04, 2026 8:00 pm
UPDATE: It's been a couple weeks since I last posted progress information on the repair of my friend's 1926 Touring balky (to be read: dead) generator. In the intervening time, I followed all the suggestions made in this thread and picked Ron Patterson's brain clean (Fortunately, he has plenty left!). Ron patiently talked me through additional checks and recommendations via numerous telephone calls and emails, often initiated by Ron. I watched a number of on-line generator repair videos, read through multiple Model T manuals and studied past discussion board threads on repairing non-functioning Model T generators - but still no success. A friend's growler proved that even though this armature showed signs of surviving the Battle of Verdun with its many nicks, gouges and missing segment chunks, it passed the test. I was just SURE the armature was the culprit. Nope. No longer one of the usual suspects. No matter what I did, this generator refused to come back to life. Polarizing the generator did nothing. The ammeter's needle remained motionless, although it showed a charge with a different generator. This was becoming frustrating. Most of the last month has been spent ordering and waiting for parts, as well as continued assembly/disassembly. Only as of today can I bring this thread to a merciful end.
To review, I rebuilt the brush plate with plastic insulators, sanded the armature's commutator plates with progressively finer sandpaper, cleaned out the micra troughs with a hacksaw blade, bought new brushes that I seated to the contour of the commutator, sealed exposed armature windings with Glyptal and purchased a new terminal wire to replace the frayed one. After a number of assemblings and disassemblings, I have become quite adept at quickly doing this, including installing and connecting the brush and field wires, which always seemed to fight me. Still, no luck, no functioning generator. What was left?
I finally decided enough pussy-footing around with this thing and then COMPLETELY disassembled the case, removing the oil-soaked field coils. When they were out, it became obvious that someone even dumber and less electrically-minded than I had been inside. Look at the attached photos of the coils and see how many stupid "fixes" a previous owner had inflicted upon them, from twisted connecting wires to broken field leads TAPED together, but disconnected inside!!! Yikes!!! No wonder this poor generator wouldn't work! After ordering and installing new field coils this past week, bench testing with a 6volt battery and initially setting the brush plate's null point to get in the ballpark for charging rate provided reason to be confident that the generator would at long last finally "gen".
Once it had been installed on/to the engine for the millionth time, I crossed my fingers, turned on the ignition key and hit the starter button. The engine came to life and to my sheer delight, a positive charge registered on the ammeter. At long last - success! The problem all along had been the field coil's previous "repairs". To my untrained eyes, the coils had looked good inside the case, albeit oil-soaked, no torn wrappings. I mistakenly believed the field coils were still usable. You cannot imagine the relief I experienced when I saw that ammeter needle sitting at 5 amps and holding steady. I hope I can get past all the sleepless nights, anxiety-filled days working on this ^%$(& generator and the hours spent reading manuals and watching videos about generator repair. Perhaps my frustrating experience will help others here, who are likewise experiencing generator repair issues. If I can fix this generator, ANYONE can.
Besides all the guys here who offered the benefit of their knowledge and made excellent suggestions, I want to give a special shout out again to Ron Patterson for his unswerving and patient support. If it hadn't been for his willingness to help an idiot like me resolve this generator problem, I would have given up long ago and sent the whole shebang out for an expensive exchange rebuild plus expensive shipping both ways. We are fortunate to have folks like Ron on this discussion forum, who have the knowledge and willingness to help another Model T guy keep his sanity. Thank you, thank you, thank you!!! Thanks to ALL of you, who helped!
Marshall
Post by TXGOAT2 » Wed Mar 04, 2026 9:35 pm
Sometimes what you know is right is what is wrong.
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Thu Mar 05, 2026 1:27 am
Right. :)
M.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Mar 05, 2026 4:01 pm
In the past I have removed the wire from the cutout and connected a battery charger to that wire (being careful not to ground either one of them) and the other charger wire to a bare spot on a manifold nut.
This may not be a very professional approach, but if the ammeter shows a charge, the problem is isolated to the cutout or the generator and proves the ammeter and all the wiring is correct and good.
AndreFordT
First Name: Andre
Post by AndreFordT » Fri Mar 06, 2026 2:14 am
Thank You Marshall for sharing your generator story.
I was there about 10 years ago and it was also Ron that walked me through the problems, mostly by mail. (Phone from Belgium to the USA is possible but not easy time differences)
Since than I use always his advices when I rebuild Generators, starters, coils and magneto coilrings.
Good luck
Andre
Belgium
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Fri Mar 06, 2026 9:54 am
Andre in Belgium -
Your photos could be switched with mine and no one would be the wiser. :) I took almost exactly the same photos as you did to document what was purchased and what the parts (new and old) looked like when spread out. I didn't do the mass photo of parts like your "exploded" layout view, but the others could have been taken right here in Davenport, Iowa! Great minds do think the same, don't they? :) :) :)
Yes, this generator would have been D.O.A. (Dead On Arrival) if Ron Patterson had not advised me what to do and just as importantly, what NOT to do. Advice from other posters was also very helpful and I appreciate all their time and effort they expended to write out suggestions. I hope to be able to help others on this Model T website by supplying experience gained fixing other components. Quite frankly, my comfort zone is in the Model A world, where on one discussion forum I have supplied a couple thousand postings to help newbies with their Model A problem du jours. Maybe someday I can catch up in the Model T world and be able to contribute useful advice. With willing and knowledgeable old hands like Ron offering the benefit of their experience, a LOT of us struggling Model T fans on this website will eventually be able to pass on advice in the future to newbies finding their way here - probably as clueless and desperate as I was with this "Generator from H*ll". :).
Marshall
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sat Mar 07, 2026 8:06 am
While the Model T is a simple car sometimes they can be a real challenge.
When stuck on a repair go back to the beginning and think of what is going on.
And when really stuck the best advice I have is - Trust nothing, Verify everything.
These cars and parts are now 99 or more years.
That life is filled with good and bad experiences including wear, rust, neglect, gunk, wrecks, bad parts, bad repairs, shortcuts, and "customizations".
Sometimes I think that it's a miracle that they survived for us to enjoy today.
Learning is a very important part of life, keep challenging yourself and learning.
Mike
