Are the brake cam levers for a '26-'27 the same left and right?
I know the cams are different for each side.
Thank you
'26 - '27 brake cam levers
Chad_Marcheese
Topic author - Posts: 257
- First Name: Chad
- Last Name: Marcheese
- * REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Speedster Gow Job
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Re: '26 - '27 brake cam levers
The levers should be the same right and left
Mark Chaffin
- Last Name: Chaffin
The cams are right and left. The arms are the same.
Chad_Marcheese
- First Name: Chad
Thank You Mike and Mark. That's what I was hoping you'd say.
