Gas filter screen
Last Name: Hatch
Gas filter screen
Post by Dan Hatch » Sat Jan 17, 2026 8:41 pm
How do you guys attach new gas filter screen inside the “potato “?
Got some to replace and don’t want to reinvent the wheel. Thanks Dan
Pep C Strebeck
First Name: Joseph
Last Name: M
Re: Gas filter screen
Post by Pep C Strebeck » Sat Jan 17, 2026 8:45 pm
I have always soldered them in place.
Post by DanTreace » Sat Jan 17, 2026 9:16 pm
Have used a little 25w elec solder pistol , removed the old screen, then touch around the edge to heat up the residue solder in the rim groove.
Lay in the new screen, touch tack in a few places so it won't shift. Then heat and apply solder....more you do the better you get ;)
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sat Jan 17, 2026 9:19 pm
I lay screen across it, and pop in a manifold packing center ring doo dah, then trim. Works fine.
Post by speedytinc » Sat Jan 17, 2026 10:19 pm
I did the job differently.
Originally the screen ws crimped in place by a thin outer rolled edge.
I put the outlet fitting in my lathe & cut a grove inside to fit a large snap ring.
Laid a larger piece of screen into the inside pocket & set the snap ring in then trimmed the excess screen.
Bonus advantage, I can easily replace the screen if it needs replacing when I hit 130 years old. :D :D
Post by Allan » Sun Jan 18, 2026 7:34 am
John is correct in my experience. The original screens were crimped in the brass fitting. If there is solder there, the screen has already been replaced at some time. Just do the same again.
Last Name: Hatch
Post by Dan Hatch » Sun Jan 18, 2026 7:58 am
Has anyone tried annealing the bras crimp ring and re crimping it?
Also anyone here live close to Hartsville SC?
Post by Original Smith » Thu Jan 22, 2026 1:42 pm
Why not sell the whole cap with the screen crimped in like original?
Post by RajoRacer » Thu Jan 22, 2026 3:05 pm
Snyder's does BUT you have to purchase the complete sediment bulb !
