Roller bearing long term storage.
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Post by Daisy Mae » Mon Jan 19, 2026 1:30 pm
So just picked up a set of used rollers Chaffin's was selling recently, got them all cleaned up nice & purty, question being, what is the preferred method for long term storage, especially given I'm in humid/coastal salt air.
Let me know all your suggestions....
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Roller bearing long term storage.
Post by Dan McEachern » Mon Jan 19, 2026 1:45 pm
This stuff works pretty well for preventing corrosion on bare metal:
https://www.mcmaster.com/10245K52
LPS also works well or Boeshield, but its much more expensive.
Post by RajoRacer » Mon Jan 19, 2026 1:54 pm
Greased up & zipped up in a baggie.
Post by speedytinc » Mon Jan 19, 2026 1:58 pm
Either of the previous 2 answers.
I use LPS #3. its like a thin cosmoline. Then bag.
If the bag stays intact, you can directly install by greasing without removing the LPS.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Mon Jan 19, 2026 2:14 pm
Thank ya'll!
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Mon Jan 19, 2026 4:26 pm
I vouch for lps, it's a good product.
Lps 1 is a good greasless lubricant
Lps 2 is a good oily lubricant and a little thicker
Lps 3 is great for preventing corrosion and providing a long lasting semi self healing film.
Post by John kuehn » Mon Jan 19, 2026 4:42 pm
Nothing special but a coating of some kind of wheel bearing grease inside and out will do the job. Not a bad idea to put them in a large baggie. When it’s time to use then put in a container of diesel and clean them up. Ready to go.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Jan 20, 2026 10:13 am
I use B’laster Surface Shield®
https://blasterproducts.com/product/surface-shield/
It is very sticky and slimy so I put it in a zip lock bag after coating.
It can get very messy easily.
And it washes off easily when you finally want to use the part.
A lot of lubricants can prevent rust if put in a plastic bag.
I gave up using while lithium years ago, I blamed it for rust under the grease sometimes.
I could not prove it but I suspected it.
Mike
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 20, 2026 10:32 am
Mike,
Well, I'll confirm your suspicions about white lithium.
When I tore down my TT in the 80's I had to store machined parts until I had the money to restore. That was one of the recommendations then, greased up and wrapped in oil cloth.
Only to discover later the onset of serious rust after only about 4 years. And that was in arid Calif.
Why I had to ask, figured better options now.
